    Suunto 9 baro - GPS track not accurate
    80 Posts 12 Posters 8.8k Views 13 Watching
    • florin2528F Offline
      florin2528 Bronze Member
      I’m a new with Suunto, but I have tested other vendor watches.
      I own a Suunto 9 baro and after a couple of runs i was thinking to compare with my phone track.
      For a 8.41 km run there is already a difference of 110 meters and 14 meters for altitude. The track on the map looks really bad, has nothing to do with the path i was running, it’s always a couple of meters on the right side of the trail(10 -15m). Corners are pretty bad also.
      I was running in performance mode, only with GPS set for navigation(no glonass), latest software update.
      Please let me know what to expect from this watch?
      ? EgikaE 2 Replies Last reply Reply Quote 0
        A Former User @florin2528
        @florin2528 said in Suunto 9 baro - GPS track not accurate:
        How do you know the true distance and altitude?
        Suunto 9 does cut corners which I have a problem with too, but in my experience it is still more accurate than most other GPS watches.
        florin2528F 2 Replies Last reply Reply Quote 2
          Egika Platinum Member @florin2528
          GPS accuracy can’t be judged from a single event (not even a few), since it is influenced by soo many factors (satellite positions, topography, sun activity, antenna position, etc etc)
            florin2528 Bronze Member @Guest
            @silentvoyager
            the below one is from suunto 9.
              I war reading another thread and I will try to do calibration of the compass before run.
              Any feedback is welcome.
                zhang965
                please wait for next firmware’s enhancement, even I don’t think it will get better.
                  Dimitrios Kanellopoulos Community Manager @florin2528
                  @florin2528 do a watch reboot via 12s upper button and sync the AGPS daily please.
                  florin2528F 1 Reply Last reply Reply Quote 0
                    florin2528 Bronze Member @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos I will do the reboot today, regarding the AGPS sync, it’s done daily.
                    I will get back with feedback after my next run.
                    Do you have some numbers regarding extra battery usage if I will enable GLONASS also?
                    Thanks for getting back,
                    Florin
                      @florin2528 those numbers show on your prestart screen. I think the damage is ~2h (on a 100% charge)
                        had another run where GPS was ok, not very accurate, but ok. Today I had another run where GPS went crazy.
                        I’m attaching the route from telephone (galaxy A15) and the one from watch.
                        I’m sorry to say, but suunto9 can’t be trusted. I was in an area with small houses, nothing that can result in something like this.
                        I was previously using a fenix 5 and had no issue with the track(shitty battery - but that something else).
                        Please advise.
                        Florin
                          zhang965
                          I’d advise you to move to another country and give it a try.
                            freeheeler @florin2528
                            @florin2528
                            they both look quite off to what I am used to 😕
                              florin2528 Bronze Member @zhang965
                              @zhang965 I don’t understand you, what country has to do? My cheap phone has a decent signal, why shouldn’t have the suunto 9. I had a fenix 5 which had no issues in this country.
                              • Mff73M Online
                                Mff73 @florin2528
                                @florin2528
                                @zhang965 has a very high sense of humour 🙂
                                But after first joke, he mainly explains his real thougt 😂
                                • Mff73M Online
                                  Mff73
                                  And surely here, he might imagine that location of your run and/or specific day GPS conditions, may not be perfect.
                                  Btw, the straight line in your watch recording is not good 😞
                                    azeanic
                                    GPS is quite cranky this week. Been noticing that the tracks aren’t particularly great.
                                      florin2528 Bronze Member @Mff73
                                      @Mff73 the conditions were not perfect, a couple of thin clouds. Regarding the houses around I attached a picture.
                                      google coordinates where it lost signal:
                                      https://www.google.com/maps/@45.7875149,24.1385937,3a,75y,200.91h,97.06t/data=!3m6!1e1!3m4!1sTKMNfv5IRzW3JO-Yg_GOWA!2e0!7i13312!8i6656
                                      I still have two weeks for returning the product back. Any chances of getting a software update until then?
                                      Thanks,
                                      Florin
                                        zhang965
                                        I don’t think my S9 has a good GPS track accuracy but I think mine has not same as worst as yours.
                                        You have to do several tests to make sure where is the problem.
                                        Do a 12s reboot and update AGPS.
                                        Try once in same route.
                                        Try another route (another country)
                                        Try another day. (sunny day without thin cloud)
                                        Try with Glonass(sometime/some countries Glonass is better than GPS)
                                        florin2528F 2 Replies Last reply Reply Quote 0
                                          @zhang965
                                          Do a 12s reboot and update AGPS. - Already did that and the calibration step.
                                          Try once in same route. - I already did that and the track was decent.
                                          Try another route (another country) - don’t see the relevance.
                                          Try another day. (sunny day without thin cloud) - don’t see the relevance. If my phone works in cloudy day, suunto should also.
                                          Try with Glonass(sometime/some countries Glonass is better than GPS) - I will and get back on this thread.
                                          Here i was in the mountains:
                                          but this watch is used for tracking of the rebullXalps athletes. It should work also in the mountains.
                                          Florin
                                            @zhang965
                                            an example from another run, same place.
