    Smart Sensor battery status
    24 Posts 12 Posters 2.8k Views 11 Watching
    • florin2528F Offline
      florin2528 Bronze Member
      I have an S9 and i’m using Suunto app on the phone.
      I have bought a smart sensor also and sometimes it works and sometimes not.
      Is there any possibility of checking battery status? on the watch or SA?
      I was trying to add the sensor to the app and the options doesn’t exists.
      Cheers,
      Florin
      jthomiJ 1 Reply Last reply Reply Quote 8
      • jthomiJ Offline
        jthomi @florin2528
        @florin2528 Right now that feature doesn’t exist, not in the app or the watch. As far as I know, only way to see battery status of the smart sensor is with the Movescount app.
        Mff73M florin2528F 3 Replies Last reply Reply Quote 0
          Mff73 @jthomi
          @jthomi said in Smart Sensor battery status:
          Not in Android, it has never worked. 😜
          Any other sports app show batterie level.
          • suzzloS Offline
            suzzlo Moderator
            Hi, I always do 2 things (with my Polar H7)
            1. Each time I finish using, I remove sensor from band (avoid sensor continues detecting HR while it’s in the drawer
            2. I have always installed this app https://play.google.com/store/apps/details?id=com.lapis_semi.bleapp
            BR
            Garmin: FR745, Edge 530
            SA topics:
            florin2528F 1 Reply Last reply Reply Quote 1
              florin2528 Bronze Member @jthomi
              @jthomi
              I tried with Movescount app and it’s not working.
              jthomiJ 1 Reply Last reply Reply Quote 0
                florin2528 Bronze Member @suzzlo
                @suzzlo
                great advice, it’s working.
                many thanks.
                  @jthomi
                  I hope that suunto will get there, considering the prices they ask for products, you expect features like this to be available.
                  Thanks,
                  Florin
                  • suzzloS Offline
                    suzzlo Moderator @florin2528
                    @florin2528 You are welcome
                    SA topics:
                    • jthomiJ Offline
                      jthomi @florin2528
                      Wasn’t aware that you are using Android.
                      @florin2528 said in Smart Sensor battery status:
                      @jthomi
                      • R Offline
                        Rainer Joswig
                        I would think that showing battery status is basic functionality everyone would expect from day one. I can’t understand why Suunto doesn’t have it in the watch and the Suunto App.
                        Also I would think that the watch should warn about low-battery status of a connected Smart Sensor.
                        I have a Stryd sensor and the corresponding App shows battery level and does firmware updates. There is a smaller vendor who can support its hardware. Why not Suunto?
                        Also it seems that I can’t even pair my Smart Sensor with the iOS Suunto App? How is that possible?
                        Some time ago Suunto has announced that the Suunto App is the future. It still can’t do basic things with the Suunto hardware, like updating and showing battery levels. Which is even more disappointing, since the Smart Sensor is expensive and the performance is less than stellar, and which also degrades with too low-battery levels…
                        M 1 Reply Last reply Reply Quote 12
                          Mauerwegler @Rainer Joswig
                          @Rainer-Joswig Seems that this has not changed at all. I tried to record with the iOS app today and I could add a heart rate graph, but it did not show the HR. But in the SA settings I can see the Smart Sensor. 😩 Very weird. The Smart Sensor worked this morning with the SSU. And I‘m also searching how to check the battery level on iOS…
                          Vertical All Black
                          Vector
                          iOS Suunto App (beta)
                            DF130 Bronze Member @Mauerwegler
                            @Mauerwegler There are free apps to find/list/connect to BT devices in the range of the phone, which also report battery levels for the SmartSensor.
                              Egika Platinum Member @DF130
                              @DF130 I am using this one
                              https://apps.apple.com/app/id1509085044
                                Mauerwegler @Egika
                                @Egika said in Smart Sensor battery status:
                                That is the one I found yesterday as well that looked good (many apps help to find the Bluetooth device, not necessarily to show its properties), but it needs iOS 17. Any other recommendations for iOS 16?
                                Vertical All Black
                                Vector
                                Mouse CruiserM 1 Reply Last reply Reply Quote 0
                                • Mouse CruiserM Offline
                                  Mouse Cruiser Bronze Member @Mauerwegler
                                  @Mauerwegler I used that one: https://apps.apple.com/us/app/lightblue/id557428110
                                  Suunto 9 Baro
                                  Suunto Spartan
                                  Suunto Ambit3 peak
                                  M D 2 Replies Last reply Reply Quote 2
                                    Mauerwegler @Mouse Cruiser
                                    @Miš-Kan Ah, thanks! That was the other one I also had found yesterday, but then could not find anymore later! Just remembered the fist logo but it did not show up again in my searches. I see that in this forum we seem to find and prefer the same apps, that is a good sign that our swarm intelligence is working.
                                    Vertical All Black
                                    Vector
                                      DF130 Bronze Member @Mouse Cruiser
                                      @Miš-Kan That is the one I actually use as well 😀 !
                                        DF130 Bronze Member @DF130
                                        @DF130 But the one @Egika mentioned or also https://apps.apple.com/de/app/nrf-toolbox/id820906058 (never tried, just found when searching recently) might be slightly better in terms of data protection.
                                          Swaddy61 Silver Members
                                          Just for people’s information - the Android version (from the ‘Play’ Store, also works pretty well!
                                          herlasH S 2 Replies Last reply Reply Quote 0
                                          • herlasH Offline
                                            herlas Silver Members @Swaddy61
                                            @Swaddy61 can you share android link to avoid confusion?
                                            So far I’ve used Bluetooth Baterry on Android https://play.google.com/store/apps/details?id=com.infraware.BluetoothBattery
                                            Want to compare if I get same results or no
                                            Thx
                                            SRS Ti
                                            Galaxy Z Flip 3 / Galaxy S24+
