    Suunto 7 Altitude Issues
    321 Posts 34 Posters 107.1k Views 35 Watching
      Lars Klemmer
      On the S7 the GPS is okay, but the altitude measurements are terrible. I have these issues on all activities. No altitude measurements are correct.
      https://www.suunto.com/move/larsklemmer/5e943ce6a310d64d5b06f753
      pilleusP sartoricS Brad_OlwinB Eric Verwoerd 0E 4 Replies Last reply Reply Quote 3
      • pilleusP Offline
        pilleus @Lars Klemmer
        @Lars-Klemmer I canโ€™t confirm that. Only while kayaking the S7 is showing an ascent at the end of the activity.
        Walking, cycling, mountain biking are awesome. No difference to Ambit 3 or Spartan Ultra. I have a lot of tests and comparisons. ๐Ÿ‘
        Suunto Vertical Black Lime
        Suunto 9 Peak Pro Black
          sartoric Moderator @Lars Klemmer
          @Lars-Klemmer said in Suunto 7 Altitude Issues:
          Is your activity private ? Because the link canโ€™t be opened
          SVTS - 2.50.28
          Suunto App Android 6.10.7 beta
            Lars Klemmer @sartoric
            @sartoric sorry, itโ€™s now public.
              Brad_Olwin Moderator @Lars Klemmer
              @Lars-Klemmer I can only rely on my experiences. I have dozens of runs with both S7 and S9 and a few with A3P added in too and my elevation profiles as well as accuracy on the S7 are excellent. I am running larger hills than what might be in your example. My tests have been with hiking, Ski mountaineering and trail running. What do you mean by terrible? Is it elevation gain/loss or accuracy?
              Vector/T6c/Vertical 2 Ti
                Lars Klemmer @Brad_Olwin
                @Brad_Olwin My S7 collects to much altitude on flat routes. Last run was 400m altitude with the S7 vs. 14m (real altitude).
                  Several issues may affect the readings. When very windy, the altitude can be wrong due to wind blowing on the sensor. If the sensor is covered or gets covered and uncovered by cloth or skin it can affect altitude readings. Try a soft reset by holding upper right button 12s and see if that helps.
                    The dips ?
                      Lars Klemmer @Dimitrios Kanellopoulos
                      @Dimitrios-Kanellopoulos Correct, the round was completely flat and the watch measures mountainous round.
                        Dimitrios Kanellopoulos Community Manager @Lars Klemmer
                        @Lars-Klemmer happens always ?
                          @Dimitrios-Kanellopoulos yes, in every activity
                            @Lars-Klemmer could you do me a favor ? Record a run indoors.
                            One with wearing the watch and one without wearing it.
                            30 mins fake run each should be ok.
                            Mff73M L 2 Replies Last reply Reply Quote 0
                              @Dimitrios-Kanellopoulos said in Suunto 7 Altitude Issues:
                              no time for technical support, it is voodoo technics now ๐Ÿ˜ต ๐Ÿ˜‚ ๐Ÿ˜‚
                              SSU (retired), SV1, SV2
                              Android + Galaxy S205G
                                sartoric Moderator @Mff73
                                @Mff73 said in Suunto 7 Altitude Issues:
                                The famous and well known ghost-race ๐Ÿ˜๐Ÿ˜๐Ÿ˜
                                SVTS - 2.50.28
                                  @Dimitrios-Kanellopoulos attached the information:
                                  wearing the watch https://www.suunto.com/de-de/move/larsklemmer/5e95c8f517d4b863efb26a44
                                  watch on table https://www.suunto.com/de-de/move/larsklemmer/5e95c8f2795faf5bd61f2087
                                  Vinay MenonV Dimitrios KanellopoulosD vr2udtV 3 Replies Last reply Reply Quote 1
                                  • Vinay MenonV Offline
                                    Vinay Menon @Lars Klemmer
                                    @Lars-Klemmer May I ask what app/site those links point to? Itโ€™s certainly not SportsTracker!
                                    Vinay MenonV BulkanB 2 Replies Last reply Reply Quote 0
                                      Vinay Menon @Vinay Menon
                                      @Vinay-Menon said in Suunto 7 Altitude Issues:
                                      I found that I could access my activities in Sports-Tracker via the new UI using the activity id (and my username).
                                      • BulkanB Offline
                                        Bulkan Moderator @Vinay Menon
                                        @Vinay-Menon is sharing the link of the activity in Suunto app.
                                        If you need a web service I recommend Runalyze and Quantified-self
                                        Vinay MenonV 1 Reply Last reply Reply Quote 0
                                          Vinay Menon @Bulkan
                                          @Bulkan Thanks. Signed up to Quantified Self. Thus far it hasnโ€™t imported any of my previous activities (not sure if it trying to access data from SportsTracker or from Movescount - either way it is blank!).
                                          The web UI for the link above is a lot cleaner in design than SportsTracker.
                                          • BulkanB Offline
                                            @Vinay-Menon You are welcome, here we have the creator of QS @Dimitrios-Kanellopoulos
                                            About the import I think it works with Suunto app but not with movescount.
                                            With your input, this post could be even better ๐Ÿ’—
