    Battery duration
    42 Posts 10 Posters 3.5k Views 10 Watching
    • ianpetI Offline
      ianpet
      I wanted to try a test on my suunto baro 9 battery .
      So I charged battery fully on Friday gone and put it in power save mode and 2 day Tuesday its 47 % is this normal
        If you left it somewhere in power saving mode without using it, then no it is not normal.
        • surfboomerangS Online
          surfboomerang @ianpet
          @ianpet I did some tests in the past. Maybe it is useful to you as a reference.
          https://forum.suunto.com/topic/3674/suunto-9-baro-quick-discharge-problem/67?_=1613503046483
          • ianpetI Offline
            ianpet
            I have been wearing it
            • ianpetI Offline
              ianpet
              How do I do a soft reset
              MiniForkliftM 1 Reply Last reply Reply Quote 0
              • MiniForkliftM Offline
                MiniForklift Platinum Member @ianpet
                @ianpet said in Battery duration:
                Hold down the top right button until the screen goes off, you can then let go and the watch will do a soft reset
                That’s not normal. I charged mine to 100% on Saturday morning - it’s now Wednesday, I have done a few decent training sessions and I’m on 63% (not using power saving or anything)
                SV Titanium Solar Forest
                ianpetI DMytroD ldxmsgL 3 Replies Last reply Reply Quote 0
                • ianpetI Offline
                  ianpet @MiniForklift
                  @miniforklift will I lose my software update
                    DMytro @MiniForklift
                    @miniforklift depends on the settings. My 2 yo s9 lasts about 3-4 days with whr 24/7 and sleep tracking but no notification and about 5-6 hours of activity during this period.
                    • ldxmsgL Offline
                      ldxmsg Bronze Member @MiniForklift
                      @miniforklift I would say that mine decreases by about 10-15% per day, and that’s with smart notifications, 24hr HR and sleep tracking. I normally use GPS each day for a run or dog walk (which uses additional battery obviously), so on average I charge it every 4 days.
                      ianpetI 1 Reply Last reply Reply Quote 1
                      • ianpetI Offline
                        ianpet @ldxmsg
                        @ldxmsg but will I lose my software update if I software reset
                        ldxmsgL 1 Reply Last reply Reply Quote 0
                        • ldxmsgL Offline
                          ldxmsg Bronze Member @ianpet
                          @ianpet Not for a soft reset - it basically turns your watch off and on again. As was said above, hold down the top right button for around 12s and the screen will go dark (at which point you can let go) and will automatically turn on again a few seconds later. I probably soft reset mine once per week to clear the phantom calendar notifications that won’t disappear (that’s a whole different story!).
                          • ianpetI Offline
                            ianpet @ldxmsg
                            @ldxmsg and does it help the battery length
                            MiniForkliftM Mff73M 2 Replies Last reply Reply Quote 0
                              I would guess no. Sounds like there’s an actual issue with your watch so I’d be getting in touch with Suunto CS
                                Mff73 @ianpet
                                @ianpet
                                Softreset is more just , ‘turnoff watch and turn it on’
                                You won’t loose any settings, it is like restarting (like for your phone).
                                The only thing to do after a “softreset” is to connect to the app to sync again the GPS assisted data.
                                And in your case, after softreset, proceed to full discharge of watch and full charge to let the watch software calibrate the battery again.
                                Softreset won’t modifiy anything in the battery hardware, but sometimes battery software management need to be resetted (the software has some mess in the battery measurment gauges), thus softreset can just clean this.
                                • ianpetI Offline
                                  @miniforklift I did a soft reset just b4 bed at 42% and this morning battery 37%
                                  ldxmsgL MiniForkliftM 2 Replies Last reply Reply Quote 0
                                  • ldxmsgL Offline
                                    @ianpet Is that with sleep tracking, HR and notifications on? If so, doesn’t seem too unreasonable.
                                    ianpetI 1 Reply Last reply Reply Quote 0
                                    • ianpetI Offline
                                      ianpet @ldxmsg
                                      @ldxmsg yes I left all on
                                        DMytro @ianpet
                                        @ianpet it’s normal then
                                        • ianpetI Offline
                                          ianpet @DMytro
                                          @дима-мельниченко oh thank God for that even tho I charged it Friday gone
                                          • ianpetI Offline
                                            ianpet @ianpet
                                            @ianpet when I charge it fully next will I leave on e everything
