    GPS accuracy - track and field
    32 Posts 14 Posters 3.4k Views 14 Watching
      TM0702
      Hi, I am new to this forum. Last week I used my Suunto 9 track and field sports mode and the GPS mess up so badly. (See the pic attached.) Can anyone help me to fix the problem? InkedScreenshot_20210217-215306_LI.jpg
        Brad_Olwin Moderator @TM0702
        @thomas-ma We need to know how the watch was set and whether or not the AGPS was updated or not.
          TM0702 @Brad_Olwin
          @brad_olwin Hi, where can I check the setting?
          surfboomerangS Mff73M 2 Replies Last reply Reply Quote 0
            surfboomerang @TM0702
            @thomas-ma Nice artwork! 😁
            If you have a Suunto 9 you can find the information @Brad_Olwin asked for under settings->general->about
            My own Suunto 9 was also struggling with GPS yesterday so it’s maybe just a bad day.
              zhang965
              Did you stop your move during your run?
              • K Offline
                kamarasm Bronze Member @surfboomerang
                @surfboomerang Hell yeah, I experienced some bouncing in GPS signal yesterday, however there was never problem like this before.
                Interesting 🙂
                • Mff73M Online
                  Mff73 @TM0702
                  @thomas-ma
                  It doesn’t really look like non accuracy, as it is really “geometrical” 🙂
                  Have you eventually transfered the same workout to another plateform to compare the representation ?
                  SA activity link or fit file may help to see what is inside (wrong data, wrong representation, raw data behind for suuntoguys).
                    TM0702
                    Thanks all. So I followed the instruction above and switched to another GPS system to “Galileo.” Attached is the tracking map.
                    My next question is the accuracy: I ran 12.5 laps, which should end up equal to be 5k. However, the Suunto shows 5.38km. I ran on Lane 4 which is 423m per lap, and it should equal to 5.28m, I know 100m discrepancy is not huge but my friend is using another brand, Coros and his watch’s discrepancy is only 10m. We ran side by side as well.Screenshot_20210221-203740.png
                      DMytro @TM0702
                      @thomas-ma i think coros has a special feature for lap running where it averages out gps descrepancies so you get nicer track + more reliable distance.
                        TM0702 @DMytro
                        @дима-мельниченко Agree. In general I am quite happy with my Suunto 9 tracking.
                        Does anyone know if there is any different GPS tracking function between “Track and Field” vs “Running” function? If no, should I just use “running” function for running at the sports ground going forward?
                        surfboomerangS zadowZ 2 Replies Last reply Reply Quote 0
                          @thomas-ma I noticed running profile does not record GPS every second, but a random interval between 1-4 seconds. On road races with distance of half a marathon I noticed the watch is always spot on in distance, but on a 400m track I can imagine it cuts the corners less accurate then it should do.
                          Maybe that explains the difference.
                            This is from this morning in Amsterdam. Standard running profile, GPS+Beidou.
                            Dimitrios KanellopoulosD DMytroD T 3 Replies Last reply Reply Quote 0
                              Dimitrios Kanellopoulos Community Manager @isazi
                              @isazi I know the place well 👌
                                DMytro @isazi
                                @isazi image isn’t from SA, right?
                                  isazi Moderator @DMytro
                                  @дима-мельниченко Runalyze with ESRI satellites view.
                                    TM0702 @isazi
                                    @isazi said in GPS accuracy - track and field:
                                    Interesting. Next time I will try the GPBeidou system and see if it reports better result.
                                    And you can tell from the screenshot (from Strava) my GPS is completely off track.pic.png
                                    • zadowZ Offline
                                      zadow @TM0702
                                      @thomas-ma
                                      Hi, have you tried “Track and Field” Sport mode for running on track? I can remember that I read somewhere that it (should) has some special setting for tracking running on Track. I have never tried it by myself. It just rang the bell for me, when I read your post…
                                      Suunto Race
                                      Suunto Smart Sensor
                                      Wahoo Tickr FIT
                                      Hammerhead Karoo 2
                                      Swim Ride Run Rest Repeat
                                        Dimitrios Kanellopoulos Community Manager @TM0702
                                        @thomas-ma keep in mind that the satelite overlay isnt always 1:1.
                                          TM0702
                                          Thanks. i understand it is not always 1:1.
                                          May be next time I will try the normal “running” mode while running on track and see if there is any difference.
                                            TM0702
                                            So I run another 10k using the regular run function, and here is the map from Strava. 10k should be 25 laps, but I think I ran 24 laps + 250m(?) from the map.run.png
