Running in a tunnel caused issues in the total distance computation
59 Posts 11 Posters 4.3k Views 12 Watching
    tuxella Bronze Member
    I ran a couple of times in a tunnel with my watch (S9 Baro) and it caused the total distance to be very off (so wrong that strava flagged it).
    Here are the activities, on strava and QS :
    30/03/2021:
    • https://www.strava.com/activities/5036520007
    • https://quantified-self.io/user/JbyRpWWlliUl8tBDkpWbbh73h5B2/event/975238d06e48341364aafa086da3180a5ace4ffacc918480990f8492635200b7
    09/03/2021:
    • https://www.strava.com/activities/4917350585
    • https://quantified-self.io/user/JbyRpWWlliUl8tBDkpWbbh73h5B2/event/d2cdf19fe7f26908a7604e0d1739699ad5a76daafde081534e03d47b537dd5a5
    When looking at the GPX file and re-computing actual distance between points, the distance is ok (7.74 km, when the friend I ran with measured 7.72 with his watch).
    My current working theory is that the step length remembered by the watch is too long.
    How can I re-calibrate this length? (The track of the 30/03 was done after the firmware update, so after a soft reset AFAIK)
    D S 2 Replies Last reply 2 Apr 2021, 10:17 Reply Quote 0
      Dimitrios Kanellopoulos Community Manager @tuxella
      @tuxella the recalibration happens a the time with gps based workouts.
      If you run in a tunnel that is straight then the GNSS distance from gpx recalculation (or check it on qs) will be ok and right. If the watch reports more it indeed does not use so we’ll the fused speed or you look many times at your watch.
        The tunnel more or less follows the yellow line bellow, which I think is pretty straight.
        8032bf03-bb3a-48ed-a694-9f0f4033ecd4-Untitled.png /var/folders/8t/5y2nkcwj2bs623k4l75359xm0000gn/T/com.sindresorhus.Shareful.Copy/87060D8D-1FCC-4BA8-85E8-408B62B00074/Untitled.png
        See also the openstreetmap routing: f6e5664b-dad6-4de2-b732-c87d7f383794-image.png
        https://www.openstreetmap.org/directions?engine=graphhopper_foot&route=48.85891%2C2.33983%3B48.86052%2C2.33101#map=17/48.86011/2.33463
        I don’t think I looked at my watch more than once or twice under the tunnel (which is ~700m long). The cadence and speed reported on points while I was under the tunnel look ok to me in QS.
        Can I do anything to help the watch (using fusedtrack or not) for my next run?
          sky-runner Silver Members @tuxella
          @tuxella I suspect the watch may be double counting the tunnel distance in this case - the first time from accelerometer and the second time from GPS when it reacquures the GPS signal. The easiest way is to download the FIT file and inspect the distance over time in it, and see if there are any sharp jumps in the distance. In my experience Ambit3 had exactly the same issue, which I observed several times.
          D 1 Reply Last reply 3 Apr 2021, 09:09 Reply Quote 0
            Dimitrios Kanellopoulos Community Manager @sky-runner
            @sky-runner we have fixed this issue quite some fw before.
            T 1 Reply Last reply 3 Apr 2021, 10:05 Reply Quote 0
              tuxella Bronze Member @Dimitrios Kanellopoulos
              This “double counting” theory could explain the results I get.
              I analysed the data in the Suunto fit file from the 30/03/2021 :
              The first time in the tunnel (difference between the first and the last point without coordinates):
              • Distance: 0.87 km
              • Time: 4:15
              • Speed: 12.28 km/h
              On the way back (in the same tunnel):
              • Distance: 0.88 km
              • Time: 4:19
              • Speed 12.23 km/h
              If I add these distances to the distance calculated from GPS coordinates of each point:
              7.74 + 0.87 + 0.88 = 9.49km
              Where the total distance in the fit file (and reported in Suunto App, QS, Runalyze, Strava…) is 9.58 km
              D 1 Reply Last reply 3 Apr 2021, 11:09 Reply Quote 0
                @tuxella can you make the links of qs public ? You can easily see if it’s that bug which was fixed
                Currently I cannot open those links
                T 1 Reply Last reply 3 Apr 2021, 12:43 Reply Quote 0
                  @dimitrios-kanellopoulos They should be public now
                  D 1 Reply Last reply 3 Apr 2021, 13:25 Reply Quote 0
                    @tuxella are you using a pod ?
                    T 1 Reply Last reply 3 Apr 2021, 13:48 Reply Quote 0
                      @dimitrios-kanellopoulos No, this activity was done with just a Suunto S9 and the HR belt
                      D 1 Reply Last reply 3 Apr 2021, 13:53 Reply Quote 0
                        @tuxella I’ll take a better look when I am on my pc.
                        I do see the issue.
                        T 2 Replies Last reply 3 Apr 2021, 13:54 Reply Quote 2
                          @dimitrios-kanellopoulos Cool 🙂
                          Have a nice week-end
                          D 1 Reply Last reply 3 Apr 2021, 20:50 Reply Quote 1
                            ddausw @tuxella
                            @tuxella
                            I have the same problem with the s9b after the last FW update. The tunnel length is counted twice. I tested with Glonass as well as Galileo.
                            Dieter
                            • MiniForkliftM Offline
                              MiniForklift Platinum Member
                              Nice pace! Just gave you kudos
                              SV Titanium Solar Forest
                              tuxellaT 1 Reply Last reply 6 Apr 2021, 14:10 Reply Quote 2
                              • tuxellaT Offline
                                tuxella Bronze Member @MiniForklift
                                @miniforklift Thanks 🙂
                                • tuxellaT Offline
                                  @dimitrios-kanellopoulos Hello
                                  did you have the opportunity to check on this?
                                  Dimitrios KanellopoulosD 2 Replies Last reply 7 Apr 2021, 12:04 Reply Quote 0
                                    @tuxella I reported a bug or the watch guys.I think this new FW re introduced the issue
                                    tuxellaT 2 Replies Last reply 7 Apr 2021, 12:09 Reply Quote 1
                                      @tuxella I would like some suunto app links
                                      • tuxellaT Offline
                                        For the 30/03/2021: https://www.suunto.com/fr-fr/move/thomas430851/606310cf949ba71fa290dc8a
                                        For the 09/03/2021: https://www.suunto.com/fr-fr/move/thomas430851/60476ac697a7b66e0c4c5d8a
                                        • tuxellaT Offline
                                          @dimitrios-kanellopoulos I had this issue twice: on the 30/03 and on the 09/03.
                                          On the 09/03 I wasn’t using the “new firmware” (which was released on the 30/03 AFAIK)
                                          Dimitrios KanellopoulosD 1 Reply Last reply 7 Apr 2021, 12:27 Reply Quote 0
                                          1 out of 59
                                            consent.not_received
