    Backlight
    46 Posts 12 Posters 7.7k Views 14 Watching
    • vio112V Offline
      vio112 Bronze Member
      I just update my watch latest v 2.16.26. Why did you put away Toggle mode? Now I can bot turn off backlight when watch are active. Could you put back Toggle mode? Even if I disable Backlight in shortcuts it and enable do not disturb mode, the backlight is still on. 😥
      Is there any option how to disable Backlight?
      isaziI Tomas5T 2 Replies Last reply Reply Quote 4
      • vio112V Offline
        Even in sport activity it turn on if I hit middle button 😥
          isazi Moderator @vio112
          @vio112 select “off” for standby.
          vio112V 3 Replies Last reply Reply Quote 0
          • vio112V Offline
            vio112 Bronze Member @isazi
            I did before my testing. Backlight is stil turned on during any action.
            • vio112V Offline
              During sport activity:
              • vio112V Offline
                • vio112V Offline
                  I would expect that if I disable Backlight in shortcuts than it will be permanently disabled:
                  Dimitrios KanellopoulosD isaziI 2 Replies Last reply Reply Quote 0
                    Dimitrios Kanellopoulos Community Manager @vio112
                    @vio112 that is the backlight not the standby light.
                    Turn off the standbylight most probably
                    Creator of quantified-self.io
                    vio112V 1 Reply Last reply Reply Quote 0
                      @vio112 you mean that if you press a button the light is on, or is permanently on? Mine is always off unless I do something.
                      • vio112V Offline
                        Yes, if I press any button (action) the backlight turns on. I would like to have it permanently turned off as before with Toggle mode. For me it is absolutely useless, I do not need it automatically turned on, I would like to turn it on if I need it = toggle mode. Also it doesn’t make sense for me to have it turned on during activity, during my activities I have enough daylight and this will decrease battery life. 😥
                        • vio112V Offline
                          vio112 Bronze Member @Dimitrios Kanellopoulos
                          @dimitrios-kanellopoulos
                          I did before testing, my Standby is turned off.
                            @vio112 I thought it was always like that, a button press turns on backlight.
                            • vio112V Offline
                              No, it wasn’t. It was completely turned off in toggle mode and that was cool.
                                @vio112 never used this toggle mode, it was always working like this for me. Sorry.
                                • ChrisAC Offline
                                  ChrisA Platinum Member @isazi
                                  @isazi just checked on my not yet updated S5 and in toggle mode only a long press upper left button turns on and off the backlight - any other button press leaves the backlight turned off. So if the „toggle“ option got removed it may be that it doesn’t work like before. For me I am happily awaiting the raise to wake Option on the S5 since for my older eyes the display was always a bit hard to see - and of course I am even more happy when my S9Peak will arrive in the next weeks 😀
                                  Currently Race I
                                  • GerbsG Offline
                                    Gerbs
                                    I too am unhappy with the removal of Toggle mode. I liked being able to have the backlight off at all times and being able to quickly activate it via tapping the screen (when needed). As noted, whenever I am using the watch the backlight now stays active. It seems that Toggle mode could have been kept with the latest update.
                                    EgikaE 1 Reply Last reply Reply Quote 3
                                      Egika Platinum Member @Gerbs
                                      @gerbs same here.
                                      We covered this topic already in the FW announcement post and in a separate one.
                                      This is the third about it…
                                        Things may change again in the future, who knows.
                                        • Tomas5T Offline
                                          Tomas5 Gold Members @isazi
                                          @isazi toogle mode is even stated in suunto 5 manual. It is very weird that suunto removes functions specified in product manual. I am happy that there is development of firmware and happy that they want bring snap to route to suunto 5. But if it is in cost of loosing toogle mode, i will stay with older firmware. I used toogle mode in ambit 2s, and i use toogle mode in suunto 5 and it was one of must have features for me. I don’t need backlight during day or daylight activities but i need to be able to turn on backlight during night by simple upper left button long press.
                                          • vio112V Offline
                                            Is there any option how do downgrade it? I really need toggle mode, this is useless for me.
