    Battery saving mode.
    30 Posts 5 Posters 2.4k Views 5 Watching
    • KajkomK Offline
      Kajkom
      when turning on the battery saver mode, where the watch works like a “normal watch”, does not wake up, has a black mark and needs to be restarted, what could be the reason?
      EgikaE Al SaceA 2 Replies Last reply Reply Quote 0
        Egika Platinum Member @Kajkom
        @kajkom what do you mean by “black mark”?
        The battery saver effectively shuts down the WearOS, showing just the timem date and battery. There are no other functions available in this state.
        To use WearOS with all its bells and whistles it needs to be bootet which takes time.
        This is by design.
        KajkomK 1 Reply Last reply Reply Quote 0
        • KajkomK Offline
          Kajkom @Egika
            @kajkom yes. As said, this is by design. It is not a watch face of WearOS. The OS is completely shut down.
            • KajkomK Offline
              Kajkom @Egika
              @egika
              I understand it, but I still don’t know if the fact that the watch has the operating system turned off is slowing it down from freezing …?
              I have to restart the watch several times during the day because the screen is black
                @kajkom Can you elaborate on when you need to restart the watch?
                It goes black screen in the battery saver mode shown in your picture?
                Or it does so during normal operation?
                And can’t be woken up with the push of a button?
                There is a time out that switches off the screen after some seconds. It still should be on when you push a button or raise your wrist.
                • KajkomK Offline
                  Kajkom @Egika
                  @egika Regardless of whether I use it on my wrist or it lies on the desk top, I cannot wake it up several times a day.
                  None of the buttons work, and the touch dial also doesn’t work, and lifting the watch doesn’t work either.
                  The only and effective way is to turn it back on and put it back into battery saver mode.
                    isazi Moderator @Kajkom
                    @kajkom please contact support, there seems to be something very wrong with your watch.
                    KajkomK 1 Reply Last reply Reply Quote 1
                    • KajkomK Offline
                      Kajkom @isazi
                      @isazi do you mean to send the watch back for service?
                        @kajkom I suggest to at least contact support and communicate with them. They should help you.
                        • KajkomK Offline
                          Kajkom
                          @isazi said in Battery saving mode.:
                          supportem
                          I contacted the support remotely and they suggested a hard restart of the watch, but nothing helped, does anyone have any other ideas before returning the watch to the service?
                          • KajkomK Offline
                            Kajkom
                            I have another question, do your watches also display information on the dial as I want, once there is information (icon) of the battery and steps, and then it is not?
                            EgikaE KajkomK olymayO 3 Replies Last reply Reply Quote 0
                              @kajkom have you fiddled with developer settings in WearOS? Specifically animation factors etc?
                              Those can have an effect on watch face drawing.
                              • KajkomK Offline
                                Kajkom @Kajkom
                                @kajkom none of that, I don’t even know we can interfere with the animation?
                                KajkomK EgikaE 2 Replies Last reply Reply Quote 0
                                • olymayO Offline
                                  olymay Gold Members @Kajkom
                                  @kajkom Yes, I have this also.
                                  It does not happen often and is usually fixed by pressing the home button (sometimes a few times).
                                  It is mildly irritating but it does not affect the functionality of the watch, it is just a slight graphical glitch.
                                  I have made no changes to any of the settings in developer mode either. I’ve seen other people post about the same issue. It’s nothing to worry about.
                                  Suunto 7 Graphite Copper
                                  • KajkomK Offline
                                    Kajkom @Kajkom
                                    @kajkom
                                    ok thanks for the info. I am still going after the blow, when working in the battery saving mode, the display screen sometimes shines at about 15-20% brightness and sometimes at 100%, what could be the reason for this?
                                      @kajkom
                                      This is all pretty strange…
                                      did you buy the watch new or second hand?
                                      • KajkomK Offline
                                        Kajkom @Kajkom
                                        almost every day I encounter a similar behavior of the watch, I wonder if suunto watches are repeatable in their operation, or is it such a problem?
                                        • KajkomK Offline
                                          Kajkom
                                          recently I noticed that when I charge the watch (100% charged) and go into battery saving mode, the battery icon remains as it was before charging it, i.e. the watch is eligible for charging.
                                          Restarting makes it okay, but how many times a day you can do a restar (I will try to do and send photos for review)
                                          • KajkomK Offline
                                            Kajkom
                                            I bought a new watch in the showroom on 10/09/2021
