    Units as nmi and kts if it is metric
    25 Posts 4 Posters 4.8k Views 4 Watching
      dahab
      now my Suuonto displays the speed in kN and the distince in nmi instead of km/h and km (meters)…
      why that - I have set the units in metrics?
      robert
      freeheelerF 2 Replies Last reply Reply Quote 0
        freeheeler @dahab
        @dahab
        that’s default for nautical sports (SUP excluded afaik)
          dahab @freeheeler
          @freeheeler
            dahab @dahab
            @dahab said in Units as nmi and kts if it is metric:
            @freeheeler
            I don’t want to have it - how to change this?
            a few months ago it worked as expected - seems to be an update caused that 😞
            robert
              surfboomerang @dahab
              @dahab true… and already fixed in the latest beta. Just wait a little longer.
                dahab @surfboomerang
                @surfboomerang OK thanks
                  freeheeler @dahab
                  @dahab
                  on the watch you can always create your own sport mode and set units as you want
                    dahab @freeheeler
                    @freeheeler Ok but how about an existing custom sport mode?
                    I cannot find unit settings for that
                      freeheeler @dahab
                      @dahab
                      if you have your custom sport mode created in metric, it should remain metric (unless I’m wrong). the data that’s shown in SA was changed to nautical and since recently both units are displayed to serve both flavors.
                      edit:
                      ok, it doesn’t show units, neither in the setup on the phone nor in the datafield in the watch… so I can’t say for 100% for now
                        surfboomerang @freeheeler
                        @freeheeler The watch has two fields for speed and two for distance
                        • Speed: depending on the watch unit setting
                        • Nautical speed: Speed in kts. Independent of the unit setting in the watch
                        • Distance: depending on the watch unit setting
                        • Nautical distance: Distance in nautical miles. Independent of the unit setting in the watch
                        The app shows both in the activity summary
                          freeheeler @surfboomerang
                          @surfboomerang
                          I just checked and can not say that I undoubtedly see which is which… I also checked in custom sport mode.
                          I for one am missing units
                            @freeheeler It depends on the field settings.
                            WIth 3 fields I see the unit behind the value. On a 5 field screen I only see the icons so I am unable to distinguish the difference.
                              @surfboomerang
                              it would be cool to see the unit here 🙂
                              isaziI surfboomerangS 2 Replies Last reply Reply Quote 0
                              • isaziI Online
                                isazi Moderator @freeheeler
                                @freeheeler in this case it is not necessary, “Distance” and “Nautical distance” are different, and distance will be in km/h or m/h depending on settings.
                                  @freeheeler Yes, but then the unit setting in the watch must be made available in the app.
                                  The only fields in SA that show unit settings are vertical speed fields. But the fact that they are described as “m/h (ft/h)” indicates no unit information is synced from the watch to SA. It only indicates how vertical speed is measured
                                    surfboomerang @isazi
                                    @isazi said in Units as nmi and kts if it is metric:
                                    And this
                                      @surfboomerang
                                      maybe I miss something here… ml and cl are different, too, but in order to use the correct amount, I need to know the unit?
                                        freeheeler @dahab
                                        @dahab
                                        I’ve tried and I am confused now…
                                        SA shows both units on the phone. but I can see only metric units on my custom sport mode (kitesurfing)
                                          @freeheeler How is your custom profile configured?
                                            @surfboomerang
                                            there’s not so much to configure in terms of units
