    HR belt strange measurements
    22 Posts 8 Posters 4.7k Views 7 Watching
    • Tomas5T Online
      Tomas5 Gold Members
      Hello, it happend few time now that HR belt measure strange high heart rate. In recorded app i see max HR around 175 which can be correct but in graph i see two parts where it shows around 220 which is incorrect. Should hr belt failing? Or should i change battery?
      • Tomas5T Online
        Tomas5 Gold Members
        It looks like battery change helped.
        Łukasz SzmigielŁ ? 2 Replies Last reply Reply Quote 0
        • Łukasz SzmigielŁ Offline
          Łukasz Szmigiel @Tomas5
          @Tomas5 you may want to check your workouts in runalyze. It has a nice hrv chart - you can easily see that the battery or belt are dying if hrv is absurdly high.
          S9PP 2.44.52
            A Former User @Tomas5
            @Tomas5 I’ve had similar issues in the past. A new battery fixed it.
            • Tomas5T Online
              Tomas5 Gold Members @Guest
              Todays light ride. With new battery. I few time measured hr by hand on my neck. Watch showed from 20 - 50% more than i measured by hand.
                Mff73 @Tomas5
                @Tomas5
                Change the battery again (could be a bad new unit) and if not better, then it could be the belt itself which comes to its end.
                • Tomas5T Online
                  Tomas5 Gold Members @Mff73
                  @Mff73 i measured battery by multimeter, it is good. HR belt is just little over two year old. I will try to clean contacts by some solution for cleaning electric contacts. Hope it will help.
                  Łukasz SzmigielŁ Mff73M 2 Replies Last reply Reply Quote 0
                    @Tomas5 do you wash your belt in the washing machine sometimes?
                    S9PP 2.44.52
                    • Tomas5T Online
                      Tomas5 Gold Members @Łukasz Szmigiel
                      @Łukasz-Szmigiel no, just by hand with little bit of soap and warm watter. Not sure, but i think i never put it into washing machine.
                        Mff73 @Tomas5
                        @Tomas5
                        Voltage can be there, but battery can still be “bad” if no amp comes out.
                        Without saying it is the cause of your issues, it is just a possibility (for the price of a battery,…).
                        Can also be some electrostatic issues with your shirt, or still be the belt, even if you think it is recent.
                        The inside contacts and/or impedance of the contacts may be going into the bad side.
                        There was a website where someone explain how to measure a belt resistance and decide what to think about it.
                          Mff73
                          https://m.youtube.com/watch?v=QXJ0spt9A1E
                          Tomas5T 1 Reply Last reply Reply Quote 1
                            @Tomas5 if you happen to decide to throw it away anyway, give it a machine wash with no more than 30 deg and no rinse aid. I machine wash my H10 belt every workout. Maybe there’s some sweat or dirt residue.
                            S9PP 2.44.52
                            • Tomas5T Online
                              @Mff73 my had high resistance. I did cleaning with solution for electrical contacts and than with soap warm water. Now resistance is under 8kohm. Still a lot but at least by video it is ok if under 10kohm. I will see next time if it helped when i will go for ride.
                              • Tomas5T Online
                                @Łukasz-Szmigiel i will try next time. Strange is that with ambit watch i had belt for more than 5 years, i used it often and it is still working today. This suunto smart belt i have only little more than two years and use it only sometimes. So it is not used as much. And i do same cleaning for a years. But maybe it is just faulty unit 😞
                                • Tomas5T Online
                                  Tomas5 Gold Members
                                  Now after cleaning with solution for electrical contacts it is working fine. Tested 3 times.
                                    dombo Bronze Member @Tomas5
                                    @Tomas5 what solution did you use? imho 2 years of daily use for a belt is perfect and it is time to change 🙂 older version was failing in less then a year.
                                    Łukasz SzmigielŁ Tomas5T 2 Replies Last reply Reply Quote 0
                                      Łukasz Szmigiel @dombo
                                      @dombo nah, if it’s solid (not broken), it should work. Just give the sucker a good wash with alcohol and try again.
                                      S9PP 2.44.52
                                      • Tomas5T Online
                                        Tomas5 Gold Members @dombo
                                        @dombo i used it maybe once per month so it was really used only little. Old one with ANT+ served well more tahn 5 years of much higher ussage than this one. But for now it works again.
                                        For cleaning i used Kontox i think it is isopropyl alcohol and maybe some other chemicals. I put it on paper towel and rub it until there was black mark on paper. Did it few times and than i washed it with soap and warm water as usual.
                                          sartoric Moderator @Tomas5
                                          @Tomas5
                                          You probably know it, but be careful using IPA if you’re cleaning some part that are sealed with some sort of glue as IPA can remove or damage it
                                          SVTS - 2.48.16
                                          Suunto App Android 6.4.7 beta
                                            TyreseJ4
                                            My Suunto HR belt just stopped working a few days ago. First of all I never know if the HR belt will connect with watch. And if it does connect, it’s reporting high HR or failing to stay connected after starting the activity. It will also cause the Suunto 9 to crash every once in a while trying to load HR information after starting the activity. Btw this is all while playing around with my Suunto 9 and not actually using it for an activity. Can you imagine going going out for a run or ride while all this is happening? At this time I have no plans to purchase a new Suunto HR monitor since my primary device is the HRM pro with my Fenix 6. My Suunto gear used to be rock solid and reliable. What happened?
                                            BrunoHB 1 Reply Last reply Reply Quote 0
