    Zwift
    21 Posts 13 Posters 7.2k Views 12 Watching
    • KetoohsK Offline
      Ketoohs Silver Members
      So what is the latest on the Suunto connection to zwift?
      Just got the Wahoo Kicker One and trying to figure out how to best get the data (SA, TP, Strava).
      The only way I see it going is if I forget that I have a watch, and just run everything trough zwift (connect the HR belt, to zwift, everything else is done by the trainer). After I finnish, I DL the fit file and import it to SA. If I set the connections to Strava and TP on Zwift I would have to probably manualy delet the replicated files…
      Is there any better way? I just don’t see it and it saddens me that in 2024 I cannot do it better with Suunto.
      Karoo3 (2024)
      Vertical allBlack (2023)
      9 Peak Black (2022)
      Spartan WHR Black (2017)
      Ambit 2 Black (2013)
      Mads Hintz-MadsenM 1 Reply Last reply Reply Quote 2
      • Mads Hintz-MadsenM Offline
        Mads Hintz-Madsen Silver Members @Ketoohs
        @Ketoohs In addition to recording the ride with Zwift (and uploading to Strava through Zwift), I also record the activity in parallel on the watch (duration, power, cadence, HR. I manually add the ascent data afterwards to SA just because I like to track the amount of virtual climbing).
        Works fine for me and I don’t need to do any manual importing or use some 3rd party app to automatically import a Zwift/Strava activity into SA.
        KetoohsK 1 Reply Last reply Reply Quote 2
        • KetoohsK Offline
          Ketoohs Silver Members @Mads Hintz-Madsen
          @Mads-Hintz-Madsen How do you connect the watch, to recieve the data. I do not have any sensors on my “trainer bike”. If I had a PM it would probably work.
          Karoo3 (2024)
          9 Peak Black (2022)
          Mads Hintz-MadsenM 1 Reply Last reply Reply Quote 1
            @Ketoohs said in Zwift:
            You mentioned that you have a Wahoo Kickr trainer. If it is a newer one then it would have two Bluetooth channels. One can be used for connecting to Zwift and the other can connect to your watch.
            If it is an older Kickr model with only 1 Bluetooth channel then you could connect it to Zwift using Ant+ (which all Kickr models support) and use the Bluetooth connection for your watch.
            KetoohsK 1 Reply Last reply Reply Quote 0
            • KetoohsK Offline
              @Mads-Hintz-Madsen I have a new Kicker One (with just one cog at the back) so it most likely has dual BT. I don’t know if I pair it as a PM the watch will receive speed and cadence too.
              I guess there is only one way to find out.
              Hope Suunto does something soon for this topic.
              Karoo3 (2024)
              9 Peak Black (2022)
              • Danny polegD Online
                Danny poleg Silver Members
                I have a different kind of trainer
                I connect the trainer with ANT+ and heart rate belt to ZWIFT
                And he connects the watch with BLUETOOTH to the trainer and uses heart rate measurement from the hand
                  altcmd Silver Members @Ketoohs
                  @Ketoohs I have tried the dual recording setup before and you really have to be mindful that you don’t have auto-share enabled on one or both the platforms (swift and suunto) to Strava, etc. It will create a duplicate on Strava after every activity and then you have to manually delete them every time. Solution is one of:
                  A. Enable sharing on just one, perhaps zwift since it would have power data.
                  B. Record only on Zwift and then share to Suunto using apps like RunGap.
                  I personally use B as data from zwift to Strava is as one would expect and then sharing to Suunto gets me the required training status info without duplication (Suunto does not share it again to Strava).
                  AudaxjoeA 1 Reply Last reply Reply Quote 1
                  • AudaxjoeA Offline
                    Audaxjoe @altcmd
                    @altcmd I don’t use Swift but do record longer bike rides both on the Suunto Vertical and a Wahoo. Both share to Strava.
                    My solution is to put my default for activities to visible only to me. Then go in and delete one of the activities. Then make the other one visible to everyone.
                    A simple work around which I find easy to manage. After all how often don’t we go into Strava to adjust at least name an activity.
                    I also find it handy as I take the noise out of my account by not making visible yoga work outs and short walks but I do want to record.
                    Suunto 9 BARO
                    Garmin Fenix 3, 5
                    Suunto Vector
                    • KetoohsK Offline
                      so I connected the trainer as a Powerpod to the Vertical, and I got power and cadence transmitted to the watch but not speed (and distance), so after the exercise I manually entered the distance to the watch (and deleted the duplicates).
                      Probably have to try to connect it as a BikePOD and se what data I get. Deleting the data duplicates in Strava and TP seems inevitable for now, as I have different sports that I want to be synced from SA but love the pictures that Zwift adds.
                      Karoo3 (2024)
                      9 Peak Black (2022)
                      jcolpJ 1 Reply Last reply Reply Quote 0
                      • jcolpJ Offline
                        jcolp @Ketoohs
                        @Ketoohs Speed and distance are calculated by Zwift itself based on the virtual terrain, so you’re not going to get those no matter what from the trainer. If you do get speed from the trainer it’ll be the flywheel speed most likely, which is not equivalent so you’d have to alter it to match Zwift again.
                        KetoohsK 1 Reply Last reply Reply Quote 1
                        • KetoohsK Offline
                          Ketoohs Silver Members @jcolp
                          @jcolp So the only thing that “saves” us is that Suunto connects with zwift (@Suunto Just do it…)
                          Karoo3 (2024)
                          9 Peak Black (2022)
                          • jcolpJ Offline
                            jcolp @Ketoohs
                            @Ketoohs Not really, that would be convenient but it’s already possible to upload a Zwift activity to Suunto. You sign up with https://runalyze.com/ and connect it to Suunto. In its “Automatic Sync” functionality there is the ability to upload FIT files to Suunto. You upload the Zwift activity FIT file and it will appear in Suunto as an activity. Distance, GPS, heart rate, etc etc. It’s manual work, but it does work.
                              Download/Export .GPX file from Strava and import on SportsTracker.
                              • daveathleticD Offline
                                daveathletic Bronze Member
                                Is there any news from Suunto regarding a Zwift integration or from Zwift a Suunto integration??
                                This would help quite a lot if activities from Zwift would sync with the Suunto App.
                                I really enjoy the Suunto App and it seems like Suunto is constantly improving it. There‘s already so many integrations possible and to have a direct sync from Zwift to Suunto would be awesome, rather than a workaround via third party apps.
                                Please Suunto if you read this, you guys make the best looking watches on the market 😁, this would be a next level integration.
                                Suunto Race S Titanium
                                  larrybbaker
                                  I just record everything with Zwift and then send the activity from Strava to the Suunto app using RunGap (iOS).
                                  Vertical Ti Solar
                                  Vertical 2
                                  Race 2
                                  iPhone 17 Pro
                                  daveathleticD 1 Reply Last reply Reply Quote 2
                                    daveathletic Bronze Member @larrybbaker
                                    @larrybbaker ok, thanks for your reply, seems like a good workaround.
                                    It just would be cool to have the ability to like start a normal indoor cycle session on the watch and use a Zwift Suunto Plus App that connects to the wahoo kickr. So that the watch receives the data from it and the session is then just normally uploaded to Suunto App as an indoor cycle session. Would be a great feature. Anyway, might have to stick with Rungap for now. Thanks.
                                    fejkerF 1 Reply Last reply Reply Quote 3
                                    • fejkerF Offline
                                      fejker Gold Members @daveathletic
                                      @daveathletic the way it would work is you would do your Zwift exercise like normally (forget the watch as it’s not needed - real GPS data is not there anyway, because it’s all virtually generated and all we need is the exercise data generated by Zwift), then Zwift would have to push the data to the Suunto app via an API call. Quite easy, but I don’t know why Suunto hasn’t done it yet.
                                      Maybe Zwift is not interested or they want too much money from Suunto for the integration … who knows.
                                      SHUT UP LEGS!
                                      -Jens Voigt
                                      daveathleticD WlodiPawel 87W 2 Replies Last reply Reply Quote 1
                                        daveathletic Bronze Member @fejker
                                        @fejker alright, I see, yeah that would be amazing. Still hoping that they are working on an integration.
                                          magicedwin
                                          I’m raising the topic again, is there any news about the potential integration with Zwift?
                                          • WlodiPawel 87W Offline
                                            WlodiPawel 87 @fejker
                                            @fejker yes, just one sad thing is. When importing exercise to Suunto App it won’t show him burned calories in daily burned calories section. I have been debating about this with suunto support in chat for a while and nothing can be done. I have recently switched to Garmin which was adding kcal but not adding training into my tiredness. Best solution for the moment to me is to connect trainer to watch and zwift in parallel. Training from zwift remain in zwift and from Garmin goes to Strava for example. Also in thus case I’m not tight to zwift only. Using wahoo app too from time to time.
