    EoN CorE TanK PoD Battery
    Scheduled Pinned Locked Moved EON
    5 Posts 4 Posters 1.4k Views 4 Watching
      Franque
      Hello there, I had the battery of my tank POD changed in 2021 at the moment the connection between the POD & the Eon Core does not seem that great. Is it time to change the battery ? just over 30 dives.
      Cheers
      O J 3 Replies Last reply Reply Quote 0
      • O Offline
        Odedco @Franque
        @Franque I know it’s been a while now, so I hope you changed the battery. But in my experience, those batteries last between a year and two years regardless of how many dives you had with it. I assume the more dives the shorter the time is…
          jameslgarner @Franque
          The battery level of the POD can be seen in the screen where you pair and unpair the POD. I suggest the regular checking of the POD battery level as it can be accidentally quickly depleted if the pressure in the line/second stage is not fully released. I found this out the hard way when I had no tank pressure reading part way through a dive soon after having replaced the battery.
            @Franque
            Suunto really should consider enhancing the EON to include (1) a warning capability for POD low battery levels and (2) configurable field to enable the POD battery level to be added to one of the EON screens
            • N Offline
              NO DECO @jameslgarner
              @jameslgarner Cheers
