    Trail Running: setting default battery mode
    5 Posts 3 Posters 296 Views 3 Watching
    • OktanO Offline
      Oktan
      I have Running and Trail Running activities in my sport modes.
      When I start the Running activity - I get the Perfomance battery mode (green).
      When I start the Trail Running activity - I get the Custom battery mode (blue).
      I would like the Trail Running activity to start also with the Perfomance battery mode, as default, same as Running activity.
      How can i achive that, please?
      Suunto 9 Baro Titanium & Ambit 3 Peak
        isazi Moderator @Oktan
        @Oktan make the custom mode the same as performance, and it should default back to performance
        OktanO 1 Reply Last reply Reply Quote 0
        • OktanO Offline
          Oktan @isazi
          @isazi I tried this now: I choose the Trail Running activity (and got the blue mode), scrolled down to Options, changed the battery mode to Performance (and got the green mode), started the activity for 1 minute, stopped & deleted the activity, I started a new one ( Trail Running) - and got the Custom blue mode again, so it didnt worked.
            surfboomerang @Oktan
            @Oktan No. Like @isazi suggested, you have to adjust the settings of the custom mode so it is identical to the performance settings. Then it will default to performance the next time you start the activity.
            So before you start a trail running activity go to Custom battery mode and change the settings to GPS: Best, Touch: Map only and Distplay time-out off. (if I remember the settings correctly 😄 )
            The next time you start a trailrunning activity, it will default to Performace again.
            OktanO 1 Reply Last reply Reply Quote 1
            • OktanO Offline
              Oktan @surfboomerang
              @surfboomerang Now I got it. It worked. Thank you both!
