    Spartan Sport WHR Baro always reading HR too high at first few km while running
    43 Posts 16 Posters 7.3k Views 16 Watching
    • V Offline
      vietpq Bronze Member
      I just bought Spartan Sport WHR Baro nearly 2 months ago. I usually have problem with the WHR. It’s usually readining HR too high at first few km while running, even higher than my maximum HR. I have tried to follow Suunto guide but problem still remain (I already update lasted firmware and try to reset the watch). Following are some moves for the details:
      http://www.movescount.com/moves/move240833009
      http://www.movescount.com/moves/move240624460
      http://www.movescount.com/moves/move230077271
      Please help
      Thank you
      ? Brad_OlwinB D 3 Replies Last reply Reply Quote 1
      • SlaShS Offline
        SlaSh Platinum Member
        What works for me is to go to exercise you are going to perform but do not start it few mins before, it will engage HR sensor and GPS if it is outdoor workout, this will correct HR readings of the start. I do this usually during warm up session.
        iuliantI 1 Reply Last reply Reply Quote 2
        • iuliantI Offline
          iuliant @SlaSh
          @SlaSh said in Spartan Sport WHR Baro always reading HR too high at first few km while running:
          This also works for me too, i remain in the exercise screen (where it searches for HR and GPS) the whole warm-up and occasionally check my HR and after about 10-15 minutes of warm up i start the exercise timer and don’t have any issues during my runs. Still, there are some times when HR spikes are recorded but i guess this happens also on garmin fenix watches as well.
          SSSWHR Baro 2.0.42 | Suunto App 1.3.0 (6337) | iPhone 7
            @vietpq
            Do you wait for HR “locking” before starting your training ? Does it show the right value ?
            In some cases for a “Weight training” session I faced some similar issue but when started the training, HR were quickly “corrected”.
            SVTS - 2.48.16
            Suunto App Android 6.4.7 beta
            SlaShS V 2 Replies Last reply Reply Quote 0
            • Alberto YoldiA Offline
              Alberto Yoldi
              This issue happened to me for the last years on every watch I used. Even with external HR sensors, I always have an extreme peak at the beginning. I even thought it is my heart 😄
              • SlaShS Offline
                SlaSh Platinum Member @sartoric
                @sartoric wrist HR for weight training is awful cause of the wrist movement and hr readings are with huge delays, hr raising after you have already done the set 🙂 chest strap or forearm based ohrm are much faster to respond to fast hr beats changes.
                • V Offline
                  vietpq Bronze Member @sartoric
                  @sartoric I always turn on exercise mode, wait for HR & GPS stay at stable condition and do some warming up (about 5 minutes) before hit start button but problem still remain. Next time I will try to wait longer
                  • V Offline
                    vietpq Bronze Member @Alberto Yoldi
                    @Alberto-Yoldi do you think that is a normal situation or a problem?
                      sartoric Moderator @SlaSh
                      I know, and I’ve seen it 😄
                      But in those case I don’t need very precise data and that’s why, for now, I’m not buying a chest strap.
                      Maybe I could arrange a very long wrist band 😁
                      SVTS - 2.48.16
                      • jthomiJ Offline
                        Sometimes, before starting a ride the start screen shows a HR value of maybe 75 or 80, but when I start the exercise the watch shows twice as much.
                        I stop the exercises, delete it because of the wrong HR and start the exercise again.
                        This time when start screen show a certainly value the watch shows the same when starting the exercise. This happens from time to time, but not regular.
                        Spartan Sport with chest belt.
                        • SlaShS Offline
                          @sartoric or scosche rythm in my case, very comfortable and accurate device.
                          • SlaShS Offline
                            SlaSh Platinum Member @jthomi
                            @jthomi even with the belt? WOW thats bad…
                            jthomiJ 1 Reply Last reply Reply Quote 0
                              @vietpq I wonder how well Baro sits on your wrist, i.e. whether you have large wrists or not? Spartan units (not Trainers) are fairly big, and I’d imagine would have more of a “roll” on smaller or medium wrists as your arms move, resulting in some erroneous HR. At least, until blood circulation picks up and your limbs start to swell a bit due to all the increased blood flow.
                              Also, when you begin to run, do you shoot like a bat from hell or pick up your speed slowly in a I’m-a-weightlifter-not-runner-piss-off type of fashion? Optical HR is known to lock on cadence sometimes, especially when there’s light leaking.
                              I have Spartan Baro too and have been relatively impressed with its accuracy, enough that I no longer carry a strap or band most of the time. But then my wrists are on a larger side, I always start uber-slow, and I’m a perfect pick for optical HR from a skin complexion point of view…
                              • jthomiJ Offline
                                jthomi Moderator Gold Members Silver Members @SlaSh
                                @SlaSh Only sometimes, maybe once, twice in two weeks…
                                  sartoric Moderator @jthomi
                                  @jthomi
                                  But that looks like an issue in “transposing” what is measured into numbers … or heart at full throttle 😁
                                  SVTS - 2.48.16
                                    A Former User @vietpq
                                    @vietpq Yep, looked at your moves data… Cadence 91 (182 for both legs), heart rate 183-185… See above. I’d definitely suggest wearing the Baro higher on your wrist and making sure it sits real snug.
                                    • V Offline
                                      vietpq Bronze Member @Guest
                                      @NickK I alway wear the watch 2 fingers above wrist bone during exercise as Suunto’s guide for WHR, I also wear tight enough so can’t be able to see the light shining from the sensor.
                                      I’m experienced runner so I usually do warm up carefully and start at easy pace for first few km before speed up
                                        @vietpq I did check your moves: the watch is clearly locking on your running cadence as Valencell sensor, and many others, are known to do sometimes. Not sure there’s much you can do about it. I had a very similar issue with a few Garmin devices and their Elevate sensor a couple of years back: they’d lock on my walking cadence, “hike” heart rate to 110-115, then “chase” it all the way up to 140-150 trying to lock on something real.
                                        If you are absolutely positively sure the watch is tight to avoid any light leakage, my only suggestion would be to either try a different arm, or arm position, or really low cadence initially – like 80-110 typical for walking, or use a separate sensor like Scosche Rhythm or Polar OH1.
                                        Unfortunately, to this day wrist mounted sensors can be a hit or miss, and for you it’s clearly more of a miss.
                                          Brad_Olwin Moderator @vietpq
                                          @vietpq I have issues that are worse than yours for OHR and at this time it works for some and not for others. I believe that Suunto is working with Valencel to make this work better. We just have to wait for future updates. I use the Smart Sensor when I need accurate HR.
                                          SlaShS 1 Reply Last reply Reply Quote 1
                                          • SlaShS Offline
                                            SlaSh Platinum Member @Brad_Olwin
                                            @Brad_Olwin people reporting abnormalities even with suunto smart sensor… sometimes I feel like it is not an hr sensor itself, but something with algorithms.
                                            ? Brad_OlwinB 2 Replies Last reply Reply Quote 1
