    S9 baro ascent problems solved
    7 Posts 4 Posters 408 Views 5 Watching
    • Vrba007V Offline
      Vrba007
      Hi guys.
      There has been many questions on this topic and here is my solution.
      I had this problem over a year but I think I finally solved the puzzle.
      Anyway, for a long period of time when I was doing my hikes the watch would often had unusual spikes in my ascent profile resulting sometimes even double ascent measured than it should be. I’ve tried everything and nothing helped…
      Then once I did this the morning just before hike:
      1. Left it in warm water for 30 minues to clean the dirt from sensor.
      2. Did a watch restart (maybe most important)
      3. Calibrated compass
      4. Set altitude manually
      5. Just before START paired it with mobile phone and waited for it to get good gps signal
      Result…
      Very clean ascent profile without spikes.
      Now I don’t have any problems for at least 6 months…
      Hope this helps.
      Tomislav
        isazi Moderator @Vrba007
        @Vrba007 this is also something that is usually suggested in this forum 🙂
          sartoric Moderator @isazi
          Several times 😁
          Suunto App Android 6.3.3 beta
          • Mff73M Online
            Mff73 @sartoric
            @sartoric
            Several times? 😂
              isazi Moderator @Mff73
              @Mff73 @sartoric don’t forget to wash your watches! 😄
              • Mff73M Online
                Mff73 @isazi
                i must admit that with SV, baro holes might be quite difficult to obfuscate. “Big” holeS, putting some water in one hole and it is flowing by the other. Easier to rince than baby nose 🙂
                And if it is still required, we ( @sartoric i hope you will agree) are still ready to advise a “fridge test” 😂
                  sartoric Moderator @Mff73
                  @Mff73
                  Fridge, not freezer 😁
