    Suunto smart heart rate belt - how to check if active and connected?
    15 Posts 6 Posters 4.0k Views 6 Watching
    • V Offline
      vinc14 Bronze Member
      Hello
      Suunto smart heart rate belt.
      How to check if it is active and connected with the watch without starting a activity?
      have a nice day
      vin
      • Suunto Zoop
      Android APP: 4.100.4
        Brad_Olwin Moderator @vinc14
        @vinc14 You must have an activity running for the belt to connect. You will see the HR icon appear with straps instead of just a heart.
        Vector/T6c/Vertical 2 Ti
          A Former User @Brad_Olwin
          @Brad_Olwin @vinc14 I will also add that you can add the heart rate belt into your Suunto app and connect. Once connected it will show you your heart rate and this will show it is reading correctly. I’ve done this to make sure the belt is getting a good signal and that the battery is not dead.
          From there you can start an activity and the watch will pick it up (showing the green heart with lines)
          AudaxjoeA 1 Reply Last reply Reply Quote 1
          • V Offline
            i found out you just have to select the start - wait a bit - then the heart with straps appear
            • Suunto Zoop
            • AudaxjoeA Offline
              Audaxjoe @Guest
              @Todd-Danielczyk do you know if that works with any HRM or just Suunto?
              Suunto 9 BARO
              Garmin Fenix 3, 5
              Suunto Vector
              ? Mff73M 2 Replies Last reply Reply Quote 0
                A Former User @Audaxjoe
                @Audaxjoe Good question… I can check it tonight when I get home to see if it works with my other HR band (Coospo H808).
                I’ll keep you posted.
                Edit I am on Android so I will double confirm if it works or does not with my other “non-Suunto” HR belt - see below
                • Mff73M Online
                  Mff73 @Audaxjoe
                  @Audaxjoe
                  Dépend on OS. It seems to work with iOS, but not with android app
                  https://forum.suunto.com/post/153189
                  SSU (retired), SV1, SV2
                  Android + Galaxy S205G
                  • AudaxjoeA Offline
                    Audaxjoe @Mff73
                    @Mff73 I’m Android. I have a Polar Verity Sense OHR. SoI need to change that to a chest strap for the latest updates . Might as well go Suunto 🤷🏻‍♂️
                    Suunto 9 BARO
                    Garmin Fenix 3, 5
                    Suunto Vector
                      @Audaxjoe so I checked the Coospo on the android app.
                      And… it works.
                      Mff73M AudaxjoeA 2 Replies Last reply Reply Quote 2
                      • Mff73M Online
                        Mff73 @Guest
                        @Todd-Danielczyk
                        What?! 😳.
                        So it doesn’t work with my veritysense on my android app, but is working with your non Suunto sensor.
                        Strange.
                          A Former User @Mff73
                          @Mff73 could be that both the Coospo and Suunto are not optical where your Polar is?
                          Might be that you need a resistance style to work.
                          • Mff73M Online
                            Mff73 @Guest
                            @Todd-Danielczyk
                            Maybe, but optical or not, it is a BT device which is sending HR values. So why app won’t connect is a mystery.
                            • AudaxjoeA Offline
                              Audaxjoe @Guest
                              @Todd-Danielczyk thank you, how do you find the coospo? And which model is it? I noticed then on Amazon at a very competitive price.
                              Suunto 9 BARO
                              Garmin Fenix 3, 5
                              Suunto Vector
                                @Audaxjoe Works pretty good for me although I do like the Suunto HR better for mountain biking (gives slightly better consistency and I think it is due to the profile)
                                The Coospo H808S is the one I have and use it mainly with my indoor rower which runs Bluetooth/ Ant+ and connects just as fast as the Suunto when pairing to my watch. For the price, it is a solid choice and beep and color flash to let you know it locked/lost signal is a plus.
                                valki dhaniV 1 Reply Last reply Reply Quote 1
                                • valki dhaniV Offline
                                  valki dhani @Guest
                                  by the way i am using garmin hear rate belt. it works fine with my suunto race S
