    Suunto 9 Baro - GPS issue
    3 Posts 2 Posters 261 Views 1 Watching
    • R Offline
      Rben08
      I’m using a Suunto 9 Baro since a little more than 3 years.
      On daily basis, nothing to say, it’s a great watch.
      But, on several occasions, i found GPS issues on races, after 100km.
      Here an example :
      -> I ran twice on the same trace.
      The second one, suunto seems to just saving points and linked them, but without having any impact on distance / D+.
      On the same bit of road, first one made more than 3km, second one less than 200m.
      I was thinking fuzetrack was able to manage that. But here it looks like i was teleported.
      This pretty much break all my stats (more than 55km/h as max speed due to that teleportation)
      I must precise, i was in a forest around 10km of the center of paris, not in a deep cave or something.
      Watch was set in endurance mode, but i also saw that in performance mode.
      Is there some parameters / configuration which could be turned on / off to help a bit ?
      Or am i just stupid and don’t understand something ? 🐶
      Please, if you have any information, it’ll be fully appreciated.
      Thanks by advance !
      ReinerR 1 Reply Last reply Reply Quote 0
      • ReinerR Offline
        Reiner Bronze Member @Rben08
        @Rben08
        I’m not sure if it helps.
        Are all your regional available GPS modes activated in parallel?
        If I remember correctly, as standard only one GPS connection type is active.
        Try to turn on GLONASS or GALINEO additional, maybe you will get a better result.
        Watch: Suunto Race S
        • R Offline
          Rben08 @Reiner
          @Reiner thanks for your answer !
          I only had GPS activated. So i’ll try to use GPS + GALINEO.
          We’ll see if trace is better next time.
