    So Difference between Race 2 and Vertical 2 = Flashlight and Digital Crown
    21 Posts 12 Posters 4.2k Views 13 Watching
    • DesdinovaD Offline
      Desdinova Bronze Member
      Is there any other differences or is that it?
      • isaziI Online
        isazi Moderator @Desdinova
        @Desdinova flashlight, buttons instead of crown, larger battery, design I believe
        DesdinovaD 1 Reply Last reply Reply Quote 1
          Desdinova Bronze Member @isazi
          @isazi Just seems a small amount of differences to warrant a different name. If MIP is truly dead, then this is really only a Race 2 without a crown and a flashlight really. If larger battery is a thing, it just sits above the Race 2 like the Race S sits below the Race.
          Just seems a little odd there’s little product differentiation here.
          M B 2 Replies Last reply Reply Quote 1
            maszop Bronze Member @Desdinova
            @Desdinova said in So Difference between Race 2 and Vertical 2 = Flashlight and Digital Crown:
            Because it is cheapest for the manufacturer.
            • Tomas5T Offline
              Tomas5 Gold Members
              I like Race 2 design more. I was thinking the crown doesn’t make sense, but I like it. I don’t like to use a touch screen on a watch; basically, I prefer not to use it at all, and scrolling with the crown is convenient.
              Mister PYCM 1 Reply Last reply Reply Quote 3
                Badmo @Desdinova
                @Desdinova Race Pro 🙂
                • Tomas5T Offline
                  Tomas5 Gold Members @Badmo
                  @Badmo than we need Race Pro Max and Race Air too 😁
                  • VoiGASV Offline
                    VoiGAS Gold Members
                    I am really happy that it is (for me) disappointing and expensive. So I don’t need to buy a new watch.
                    If the Vertical 2 would have been a Vertical1 + Suunto Run features + better OHR + dive functions (like fenix) I could not resist…
                    Vertical Titanium Solar
                    AudaxjoeA 1 Reply Last reply Reply Quote 1
                    • AudaxjoeA Offline
                      Audaxjoe @VoiGAS
                      @VoiGAS haha, I thought the same but have just ordered the V2… I will have a good look at it against the V1. Like you say the difference doesn’t look great!
                      Suunto 9 BARO
                      Garmin Fenix 3, 5
                      Suunto Vector
                      • VoiGASV Offline
                        VoiGAS Gold Members @Audaxjoe
                        @Audaxjoe Normally I react the same way - the GAS in my username stands for Gear Aquisition Syndrome 😉
                        • Mister PYCM Offline
                          Mister PYC Silver Members @Tomas5
                          @Tomas5
                          I was with a RACE and I decided to shift to a VERTICAL 2 . Honestly I was a concerned by my choice because I liked a lot the crown … btu still I took the risk because I liked the idea of the red light also better lighting when white and also the batery and the bigger buttons when you do some winer sports …
                          Finally I DO NOT REGRET AT ALL my choice
                          The crowns is for sure a very good things but the way they designes the 3 buttons of the VERTICAL 2 … even I’m not using so much the touch screen
                          I’m not sayign that if the crowne was on the VERTICAL 2 I will nto have appreciated it … but it is not so mising me at the end
                          All is possible in IT
                          Driven by you fear you stay on the ground, driven by your dreams you fly
                            sky-runner Platinum Member @Mister PYC
                            @Mister-PYC One negative thing about Vertical compared to Race is that upper button is more likely to press accidentally and pause the ongoing activity.
                            In a short time of owning Vertical 2 I have already done that once.
                            OutdoorManO Mister PYCM M 3 Replies Last reply Reply Quote 1
                              OutdoorMan Silver Members @sky-runner
                              @sky-runner you can lock buttons during an activity to avoid that.
                                Mister PYC Silver Members @sky-runner
                                @sky-runner said in So Difference between Race 2 and Vertical 2 = Flashlight and Digital Crown:
                                Hello sky-runner, sthis what happening to me a lot of time with my 9 BARO, so I was used to lock the buttons during an exercise,
                                BUT there is a bad side effect when you lock the buttons, this lock also apply to the NAVIGATION map where it should not because these buttons are not risky (in the sense that it cannot pause or stop accidentally an exercice) instead it allow to zoom
                                I already suggested at the time of my RACE2 to let the zoom and scroll and eventually add a POI on teh NAVIGATION SCREEN even when teh buttons were locked
                                  @sky-runner I use the map screen to avoid accidental pauses or ending the activity.
                                    sky-runner Platinum Member @maszop
                                    @maszop Yes, that’s what I realized as well - either map of climb guidance.
                                    But I really wish there was a “race lock” mode that disables ability to accidentally pause. In fact, I wouldn’t mind the pause as long as it acted as a rest timer - with all metrics still recording and elapsed time continuing.
                                      @sky-runner Exactly – locking all buttons is often overkill. What’s missing is a less drastic option to prevent stopping or pausing the activity, but still let you use the watch normally during it – some partially locked mode.
                                      sky-runnerS Mister PYCM 2 Replies Last reply Reply Quote 2
                                        @maszop said in So Difference between Race 2 and Vertical 2 = Flashlight and Digital Crown:
                                        This is actually a big deal for me. Accidental pausing during a race had happened to me several times, and it always stresses me out. There are two issues with that. One is that I obviously lose some stats if I don’t notice the paused state right away, with potentially minutes missing. The elapsed time gets out of sync with the race time too.
                                        But another less obvious issue is that even a single pause in activity messes up Strava because that disables Strava’s moving time algorithm, and Strava no longer eliminates stopped time, which I usually rely on. The reason I use Strava’s algorithm rather than built-in auto pause is that Strava’s algorithm works way better on steep mountain terrain. So I normally never pause the watch and then let Strava remove all the stops.
                                        If there was a software option to let me configure whether the lock feature locks everything vs just pausing and stopping, I’d use the latter 100% of time.
                                          Mister PYC Silver Members @maszop
                                          FULLY AGREED !!!
                                          • Steven HambletonS Offline
                                            AU$200 for an LED light and a slightly bigger battery is too much for me.
                                            I’m hoping they introduce the LED to the Race line at some point, just like the Garmin have with the 970 and Venue 4.
                                            Watch: Suunto Race S
