    Outback Adventure (Vertical 2) watchface is public
    85 Posts 38 Posters 9.0k Views 30 Watching
      GiPFELKiND Silver Members @jannis
      @jannis i would like to see more tapable infos like the Race 2 watchface. That would solve some questions here. 🤩 Love this Option since the first Firmware at the Vertical 1 and 9 baro
      • J Online
        Jugger
        I would like to have windspeed and direction on this watchface. Then it would be perfect. I know I can put it instead of date but I want see that too. Otherwise it’s my new favourite WF.
        • pavel.samokhaP Offline
          pavel.samokha
          Merged two topics about this WF into one
            surfboomerang
            I also noticed that the weather location and temperature bar is lagging in updates. It shows old location and temperature readings and updates immediately when one of the buttons is pressed.
              surfboomerang
              The location doesn’t seem to update at all if the watch isn’t unlocked. Also the bars are still shifting and updated when unlocked.
              @pavel.samokha do you know if this is a known bug or is this by design to preserve battery?
                sky-runner Silver Members @pavel.samokha
                Speaking of this watchface, I really wish it was possible to see the temperature in Celsius while keeping other US units. After 25 years living in the US I still haven’t gotten used to Fahrenheit. All my other devices are configured to show Celsius. Even Suunto Ambit was capable of using mixed units. Am I the only one who wants this?
                • Stefano M64S Offline
                  Stefano M64 Silver Members @LitchiMonster
                  @LitchiMonster said in Outback Adventure (Vertical 2) watchface is public:
                  the place name on the weather complication is too long, and runs over the weather forecast. The place name should be truncated?
                  since the weather forecast data reach the watch via the SA, as a workaround for the too long place name, it could be possible to allow the user to set a customized name for is living place, that would replace the standard one given by the forecast provider.
                    safari @surfboomerang
                    @surfboomerang
                    The screen displays the last location in standby mode.
                    Pressing a button displays the current location.
                    In the video, the first location is my home, and the second is my workplace.
                    There’s a 10 km gap between them.
                    I didn’t do anything on the watch to test it. I pressed the side button on the watch while I was at work.
                    But this is normal.
                    wf_.mp4
                    history:
                    suunto 9 baro
                    suunto ambit 3
                    suunto ambit 2
                    Suunto Smart Heart Rate Belt
                    suunto App: apple iphone 14
                      surfboomerang @safari
                      @safari This is indeed what is happening right now, but I don’t think that should be the case.
                      I specificly chose this watchface so I can see all information at a glance, but now I have to press a button to make sure that I’m seeing the latest information.
                      The complications seem to update well. It’s only the sunrise and temparture bar and the location that update after a press of a button.
                      Not sure if Suunto did this deliberately to save battery or something?
                        @surfboomerang
                        I agree
                        I’ve been using Suunto for 15 years, I’m sure this is my biggest dream 🙂
                        I used to see more information on the home screen of my Suunto Ambit watch.
                        When the watch started to follow the trend and transition from a mountaineering computer to a smartwatch, this naturally started happening.
                        We can’t switch to watch faces during exercise anyway.
                        We’d like the watch face to act as a “dashboard” for normal use. But this isn’t possible due to the insufficient use of the home screen and the limited number of complications (Athletics) that only have six.
                        But our loyalty to Suunto is undeniable. 🙂
                        history:
                        suunto 9 baro
                        suunto ambit 3
                        suunto ambit 2
                          tailwind_mrs
                          Can we get the “dimmed view” in AOD mode for all (most… ?) watch faces to be more like the Vertical 2 (Outback Adventure) ? Instead of showing numbers with horizontal bands (dark/light) show the contour of the digits, just like in the watch face “Outback Adventure”, which looks better in dimmed view.
                          As an example, the main WF for the Suunto Run (similar to the Aero Sport in SuuntoPlus) looks great in the Run while dimmed in AOD (just the contour of the hour:minute), while in the Race S version it looks horrible… Or the adaptation of the Race S WF (Adrenaline, or Adrenaline Bulletin) that looks much better in the Suunto Run in dimmed state. And, there’s also the fact that the dimmed versions in the Race S are often off centre and much much dimmer than in the Run… which is weird, considering the more premium positioning of the Race S ?
                          An alternative, is to make both modes available (either the dark/light horizontal bands OR the contour) and selectable, just like for Complications ?
                          I find this quite important, as the dimmed view is actually what’s visible most of the time (glancing to the wrist while driving, in a meeting at work, etc), and I’ve been moving back and forth between watch faces, still struggling to find the the right one.
                          I was quite happy with the Run watch faces (even if more limited in number and no access to SuuntoPlus), but due to lack swimming metrics, I swapped it for a Race S. Only to be very underwhelmed by the dimmed state of all watch faces.
                          Please … ! 🙂
                          Garmin Vivoactive 4, Fenix 3 HR, 920XT
                          Jan Van de VeldeJ 1 Reply Last reply Reply Quote 4
                          • Jan Van de VeldeJ Offline
                            Jan Van de Velde Bronze Member @tailwind_mrs
                            @tailwind_mrs Upvoted. I like the Aero Sport wf, but not the aod version. I didn’t even realise there was a difference with the Run.
                            • PavlasP Offline
                              Pavlas
                              Lately I’ve been using this nice watch face on my Vertical 1. But it’s a shame that the color difference of the temperatures is not displayed as presented. It probably works on AMOLED displays, but not on MIP. I still see one color. When I go to the weather forecast, I also see a graph with different colors of temperatures. I can see this color difference in the display preview as well. Why can’t it be done on the watch face?
                              🔺Vertical All Black
                              ex:
                              Ambit2 Black
                              Ambit3 Peak Sapphire
                              S9B All Black
                              >>> YouTube Channel <<<
                              • segi_pnS Offline
                                segi_pn Bronze Member @surfboomerang
                                @surfboomerang
                                Today I noticed that when the watch goes to sleep, the display moves forward, and conversely, when I press the button and the watch wakes up, the display moves backward. It looks as if it counts down from a different time when it goes to sleep.
                                Now, in the middle of the day, it’s not so easy to see in the photos. In reality, I can clearly see the jump in the upper graph. I’ll try to take photos in the evening or morning when it will be more visible in the photos.
                                Suunto Core (17y)
                                Suunto Vertical Ti
                                EgikaE MiroslavaM 2 Replies Last reply Reply Quote 0
                                  Egika Platinum Member @segi_pn
                                  @segi_pn Not exactly sure what you mean, but the dusk and dawn times have a different resolution in active or standby state for MIP devices.
                                  This is most likely to save energy (like seconds not shown in standby state)
                                  PavlasP segi_pnS SquirrelS 3 Replies Last reply Reply Quote 0
                                  • MiroslavaM Offline
                                    Miroslava @segi_pn
                                    @segi_pn Trnava 🙂
                                    • PavlasP Offline
                                      Pavlas @Egika
                                      @Egika I’ve noticed that too. I don’t think it’s the resolution. It just shifts significantly when it wakes up. It looks like it’s in standby mode about an hour ahead.
                                      The color of the temperature graph also differs when it wakes up.
                                      🔺Vertical All Black
                                      ex:
                                      Ambit2 Black
                                      S9B All Black
                                      >>> YouTube Channel <<<
                                      • segi_pnS Offline
                                        segi_pn Bronze Member @Egika
                                        @Egika
                                        That’s pretty weird behavior. So in standby mode, the graph is enlarged, and when switching from one mode to another, the graph flickers because it zooms out and then zooms back in?
                                        Suunto Core (17y)
                                        Suunto Vertical Ti
                                        segi_pnS 1 Reply Last reply Reply Quote 0
                                        • segi_pnS Offline
                                          segi_pn Bronze Member @segi_pn
                                          Now it’s easier to see.
                                          d178a295-520e-4a44-862c-00fc03c65157-image.png 0b34bd7d-57b5-4e61-88f8-8e198a22dc4e-image.png
                                          and after switching to standby mode, it will return back
                                          Suunto Core (17y)
                                          Suunto Vertical Ti
                                          Stefano M64S 1 Reply Last reply Reply Quote 1
                                            Stefano M64 Silver Members @segi_pn
                                            @segi_pn I guess is an issue related to the color depth, when the luminosity decreased the fainter segment seems to disappear
                                            surfboomerangS segi_pnS 2 Replies Last reply Reply Quote 0
