    Smart Sensor HR belt: memory function with other belts?
    5 Posts 4 Posters 364 Views 4 Watching
      fv4500 Bronze Member
      Hi there! I use the Suunto Smart HR belt and I find it particularly useful when I leave the watch in the locker or in the backpack and use the memory or “standalone” function of the sensor during an activity. After, the watch and the sensor synchronize seamlessly.
      My question is if, to anybody’s knowledge, this feature is present in other HR belts or armbands. The Polar H10 seems quite notorious and Coros has its HR armband, but I don’t know of any other manufacturer than Suunto offering such function.
      Anybody with other experiences? Thanks!
      VoiGASV 2 2 Replies Last reply Reply Quote 0
      • VoiGASV Online
        VoiGAS Gold Members @fv4500
        @fv4500 Polar verity Sense also has onboard memory for activities. Unfortunately Suunto only seems to work with Suunto and Polar with Polar…
        Vertical
          2b2bff @fv4500
          @fv4500 is your question: do other manufacturers have that feature or which belts can I use to have that feature with my Suunto watch?
          The rule of thumb is that only the manufacturers of the watch can work with their own belts. So, Suunto Watches with Suunto Belt, Garmin Watches with the more expensive versions of the Garmin belts, …
            fv4500 Bronze Member @2b2bff
            @2b2bff first question is indeed if other manufacturers have implemented this in their ecosystems, but the second question you point out comes right after 🤔. Seems a quite relevant feature from my point of view. I will check the Verity Sense… Which Coros HR band does offer this in your knowledge?
            I understand that if the protocol used is the general BLE then there’s cross-compatibility?
              Squirrel Bronze Member @fv4500
              @fv4500 said in Smart Sensor HR belt: memory function with other belts?:
              There is no cross-compatibility reading the stored exercise data from belt memory between brands.
