    Smart heart belt disfunction
    10 Posts 4 Posters 1.2k Views 3 Watching
    • P Offline
      PIPA44800
      Good evening Community,
      I’m reaching out to you today because I’m having a lot of trouble with my heart rate monitor.
      Background: I became the proud owner of a Race S + smart sensor combo in August 2024.
      I used both for about 9 months without any problem, then overnight, the belt stopped turning on. I thought it might be a battery issue, so I changed the battery, but now I’m facing a new problem : the belt turns on for a few seconds and then turns off.
      To see if it’s working on my watch, I go to Connectivity > Connected Devices, and I can see the belt, but when I select it, it takes about 30 seconds to display the heart rate and battery information. Sometimes it never happens, so I have to unpair and re-pair it.
      Same issue on the Suunto app : Setting > Activity & workout > Pair an HR sensor > Heart rate monitor > Connect HR sensor = it works for less than a minute and then stops.
      When I try to start an activity with the belt, I get a notification saying that it is connected, but when I actually start, it lasts a few seconds before it stops. It’s extremely frustrating.
      The fabric belt has always been rinsed after exercise + washed in the machine once a week. I always wear it with moistened electrodes. I read on forum that the pins could be the problem, so I tried cleaning them with a damp toothbrush, but without success.
      Are there any other tests I can do before declaring it dead :
      -Change the battery
      -Reset the connection
      -Clean the band thoroughly with soapy water
      No positive results so far 😢
      Can i get some assistance please ?
      Thx, Peter
        Mattg576 @PIPA44800
        @PIPA44800 You can check the integrity of the belt using a multimeter (details at approx 5 minutes in), not sure it would throw up the issues you’re experiencing but worth ruling it out.
        https://www.youtube.com/watch?v=QXJ0spt9A1E&t=325s
        Race
        9 Peak
        Ambit 3 Peak
        Ambit 2R (sold)
        Suunto T3d (expired)
        P 2 Replies Last reply Reply Quote 2
        • P Offline
          PIPA44800 @Mattg576
          @Mattg576 Hi Mattg, i’ll check this at work tomorrow, don’t have the equipment at home 🙂
          • P Offline
            PIPA44800 @Mattg576
            @Mattg576 Hi, I was able to do the test this afternoon and the measured value is 2k ohms. The YouTuber seems to be saying that it needs to have a value lower than 10k ohms, so I can consider the belt okay in that respect?
              Mff73 @PIPA44800
              @PIPA44800
              Try another new battery, try with another app or watch, and last chance, Suunto support. Maybe some warranty is possible.
              SSU (retired), SV1, SV2
              Android + Galaxy S205G
              • P Offline
                PIPA44800 @Mff73
                @Mff73 hey, I’m going to try with a new battery; do you have any app names compatible with this belt other than the Suunto one ?
                  Mff73 @PIPA44800
                  @PIPA44800 said in Smart heart belt disfunction:
                  It is a Bluetooth sensor, any apps you want, managing HR, should be compatible.
                  • P Offline
                    PIPA44800 @Mff73
                    @Mff73 I just tested it with a new battery, no improvement on the Race S side. I tried connecting the heart rate monitor to the “Elite HRV” Android app, same result : the frequency is detected for a few seconds and then the app loses the signal with the heart rate monitor.
                    • P Offline
                      PIPA44800 @PIPA44800
                      Good evening everyone, is there no chance of getting a response from a Suunto administrator/support directly here? Do I need to submit a support request elsewhere?
                        2b2bff Gold Members @PIPA44800
                        @PIPA44800 exactly, this is not a support but a Community forum.
                        Garmin Epix Pro
