    Suunto Smart Heart Rate Belt 2
    258 Posts 49 Posters 42.3k Views 45 Watching
    • Tami999T Offline
      Tami999 Silver Members
      Image on cam2 page, since as I understand its not “official” released yet, but cam2 is legit sport shop.
      Price is set here on €111,95 EUR
      Description
      Designed for performance-driven endurance athletes, marathon runners, triathletes, and cyclists who demand absolute data accuracy. Constructed with a premium stainless steel and polymer composite housing, the SUUNTO Smart Heart Rate Belt 2 (SHRM2) captures clear ECG signals directly from the chest. Whether pushing through high-intensity intervals, racing on the road, or cycling over rough terrain, it delivers lag-free, rock-solid accuracy far superior to wrist-based optical sensors.
      High-Resolution R-Peak Detection & ZoneSense™ Optimization
      Featuring an upgraded 2nd-generation sensor array with higher resolution R-peak detection, the SHRM2 captures subtle beat-to-beat intervals (HRV). This precise data feeds directly into SUUNTO’s proprietary ZoneSense™ algorithm, offering real-time insights into your aerobic, threshold, and VO₂max stress zones during workouts.
      Torso-Based Running Form Dynamics
      Eliminate the need for additional foot pods or waist sensors! When paired with compatible Suunto performance watches (such as Suunto Race, Vertical, and Run series), the belt provides comprehensive running biomechanics:
      Ground Contact Time (ms)
      Vertical Oscillation (cm)
      Flight Time (ms)
      Left/Right Balance (%)
      Cadence (rpm) & Step Count
      Swimming Memory & Offline Storage
      During swim workouts or periods of temporary signal loss, the sensor automatically records heart rate data to its onboard memory. Once back on land or reconnected, stored data seamlessly transfers to your Suunto watch, giving you a complete ZoneSense™ and heart rate graph from the water.
      Multi-Device Connectivity & Zwift Integration
      Equipped with Bluetooth 5.4, the SHRM2 supports up to 3 simultaneous Bluetooth Low Energy (BLE) connections. Broadcast your heart rate concurrently to your Suunto watch, bike computer, and virtual indoor training software like Zwift or gym equipment without signal drops.
      Button-Controlled Security & LED Status Light
      Stay in control with a new built-in LED status light that alerts you to battery levels and connection states. Secure, button-controlled pairing and encrypted transmission prevent cross-talk and signal interference in crowded start lines.
      Ergonomic Anti-Slip Design & 30m Water Resistance
      The soft, washable fabric chest strap features a silicone anti-slip grip to keep the belt securely in place during vigorous efforts. Enhanced signal shielding prevents static electrical noise caused by dry performance fabrics. Rated 30m (3ATM) water resistant for all weather and aquatic conditions.
      Chest strap sizing range: M/L: 74-125 cm
      https://cam2.com.hk/en/collections/最新裝備/products/suunto-smart-heart-rate-belt-2?srsltid=AfmBOoozAo07JX8e4n7Ydx-_dTuzzMjDv7obcarMzQ3TV1QfEkPrB0Nv
      Thaler MartinT B 2 3 Replies Last reply Reply Quote 1
      • Thaler MartinT Offline
        Thaler Martin @Tami999
        @Tami999
        Heisst das das zone sense genauere Daten liefert mit diesem gurt?
        Ich benütze momentan die suunto race 2 mit dem garmin hrm pro plus…
        Bitte um Infos…danke
          BastMaSVSRS9PP Bronze Member @Tami999
          @Tami999 wondering if it can do ecg readings for health / heart screening style measurements without workout enabled
          SVti (Mammut Edition), SR2, Suunto Wing
            2b2bff Gold Members @Tami999
            @Tami999 yes - that is great news. Multiple connections and running dynamics is what I consider a worthy upgrade…
            Garmin Fenix 8
              OutdoorMan Silver Members @Thaler Martin
              @Thaler-Martin we don’t know, he just copy pasted the text from the website.
              • v.sacreV Offline
                v.sacre Silver Members
                Review from Joaquin
                https://www.youtube.com/watch?v=EB7Y2s_9lUY
                Suunto App: Android Beta
                • pavel.samokhaP pavel.samokha moved this topic from Accessories and other products on
                  Tieutieu Platinum Member
                  not launched officialy yet ? not visible on suunto’s website for now ?
                  On use : SV1 Ti Solar, SRs3, SRs, S9pp Ti sand, Suunto Wing & Spark
                  As collector : S9B titanium Ambassador edition, A3P, X6
                  • Tami999T Offline
                    Tami999 Silver Members @Tieutieu
                    So far I’ve found on one site in my country. Delivery 12-14/09/2026 for 120$ after exchange.
                    • thailonT Offline
                      thailon Bronze Member
                      Is it going to be supported by Vertical?
                      T3c, Quest, Ambit3 Peak, 9PP, Vertical
                      martintrailM 1 Reply Last reply Reply Quote 1
                      • martintrailM Offline
                        martintrail Silver Members @thailon
                        @thailon
                        Compatibility: The Suunto Smart Heart Rate Belt 2 is compatible with selected Suunto sports watches. Supported features vary by watch model.
                        Core features: Heart rate, RR intervals, memory, and ZoneSense are supported on Suunto 9 Peak Pro, Vertical, Vertical 2, Race, Race 2, Race S, Run, Run 2, and Ocean.
                        Running Form: Supported on Suunto Vertical 2, Race, Race 2, Race S, Run and Run 2. On selected models, Running Form requires a custom sport mode, Suunto Plus, or post-workout analysis.
                        Suunto Vertical Ti Solar
                        VoiGASV thailonT 2 Replies Last reply Reply Quote 6
                        • VoiGASV Online
                          VoiGAS Gold Members @martintrail
                          @martintrail Hope the V1 will also get “Running Form”
                          Vertical Titanium Solar
                          Eon Core
                          2 martintrailM 2 Replies Last reply Reply Quote 1
                            2b2bff Gold Members @VoiGAS
                            @VoiGAS I doubt it. As with the new navigation features introduced in Q1 only Race S and newer got it. Neither Race (limited features), nor Vertical (no update at all, yet).
                            So, if the only mention Race S and newer, I think that’s it. I wonder however what they mean with “custom sport mode, Suunto Plus or post-workout analysis”, as latter could be done on any watch that gets data from the new HRM2…
                            Garmin Fenix 8
                              martintrail Silver Members @VoiGAS
                              @VoiGAS I don’t think we’ll be able to get it onto the watch, but it would be enough to see it in the app. 🙂
                              • thailonT Offline
                                thailon Bronze Member @martintrail
                                @martintrail as I see on https://www.suunto.com/en-sk/Products/Heart-Rate-Belts/suunto-smart-heart-rate-belt-2/suunto-smart-heart-rate-belt-2-black-size-ml/ yes, there is statement “Compatibility: The Suunto Smart Heart Rate Belt 2 is compatible with selected Suunto sports watches. Supported features vary by watch model.”
                                What models aka “selected Suunto sport watches” they mean?
                                Somehow point 1 make no sense to me having points 2 and 3.
                                  Tieutieu Platinum Member @thailon
                                  @thailon https://forum.suunto.com/post/197297
                                  Isn’t the answers four post above ?
                                  Specified on Suunto’s website
                                  thailonT 1 Reply Last reply Reply Quote 0
                                  • thailonT Offline
                                    thailon Bronze Member @Tieutieu
                                    no
                                      @thailon
                                      point 1 => general statement (I agree with you it’s pretty pointless as models are listed in point 2 and 3)
                                      Point 2 => models which support core features
                                      Point 3 => models which support running form features
                                      But I certainly don’t understand correctly what you ask for ?
                                      thailonT 1 Reply Last reply Reply Quote 1
                                      • thailonT Offline
                                        @Tieutieu said:
                                        @thailon
                                        whether Vertical would require almost never coming firmware update, or if it will work as it is If I buy that HR belt now.
                                        • HighlandsH Offline
                                          Highlands
                                          The new chest strap looks promising. Just ordered one to give it a spin.
                                          2 Stefan T.S 2 Replies Last reply Reply Quote 1
                                            2b2bff Gold Members @Highlands
                                            @Highlands me too. Runing dynamics is one of the things I somewhat miss on my Race S. Also I could use more than one Bluetooth connection once in a while…
                                            Garmin Fenix 8
