    Suunto 9 Baro - compass calibration before every run?
    23 Posts 6 Posters 1.5k Views 6 Watching
      Hi every time you connect the watch to the magnetic charger the watch needs a compass calibration due to the strong magnetic field of the charger.
      Compass should be asked to be calibrated when it has an error. The preivous user of this thread had magnetic gloves.
      Do you happen to have some magnetic interference in your area?
      IF the calibration is asked once per run that is normal.
      Fiox89F 1 Reply Last reply Reply Quote 0
      • Fiox89F Offline
        Fiox89 Bronze Member @Dimitrios Kanellopoulos
        @Dimitrios-Kanellopoulos Well then it may be the charging process, I have no gloves or other possible magnetic interference. I will try to observe if this happens after charging the watch then. Thanks for the advice 🙂
        Suunto Spartan Sport
        FW: 2.8.24
        SA: 4.17.7 beta
          Dimitrios Kanellopoulos Community Manager @Fiox89
          @Fiox89 come back here if you still experience issues.
          In general, you can calibrate a compass, even if the watch does not ask it (applies also to mobiles eg google maps etc) by doing manually that 8 figure gesture.
          Digital compasses can understand most of the times if they are uncalibrated when a big electromagnetic change happens eg the magnetic charger that the Spartans have.
          I hope it clears up a bit.
