    S9 and HR belt
    30 Posts 15 Posters 2.2k Views 14 Watching
    • MaxiPalleM Offline
      MaxiPalle Bronze Member
      when connected to a HR belt, I don’t see values in the corresponding fields of my Suunto 9.
      When unconnecting the HR belt it is working again, as now HF is measured by the watch.
      Probably a misconfiguration of my individual sport modes?
      Any help appreciated.
      Jens
      ? pilleusP Brad_OlwinB EzioAuditoreE 4 Replies Last reply Reply Quote 0
        A Former User @MaxiPalle
        @MaxiPalle did you try to use a stock sport mode?
        Does HR appear there?
        • pilleusP Offline
          pilleus @MaxiPalle
          @MaxiPalle said in S9 and HR belt:
          I have this behavior (no HR data with Suunto or Polar belt) with every custom sport mode during the first activity on my Spartan Ultra. From the second activity on everything works perfect. I have no idea why this is happening!?
          Suunto Vertical Black Lime
          Suunto 9 Peak Pro Black
          MaxiPalleM 1 Reply Last reply Reply Quote 0
            MaxiPalle Bronze Member @pilleus
            @pilleus can confirm this behaviour. Tested it today. It doesn’t works as expected in a custom Sports when using it for the first time.
            But it works when using it the second time after a few seconds.
            • Václav KrálV Offline
              Václav Král
              For me works fine. I have Polar H10 belt, because Suunto strap is only for few months and its gone 😞 Today I created custom profile for bike and used it with my Polar H10 belt and no problem.👌 💪 💪
              Polar A360, Polar M600, Polar M430
              Suunto Spartan Trainer, Suunto Spartan WHR Baro
              Suunto 9 Baro
              Coros Apex Pro
              Google Pixel 2
                Brad_Olwin Moderator @MaxiPalle
                @MaxiPalle I will test this today but have never experienced this. I rarely use OHR on my S9 and almost always use the belt. Do you know the status of the battery in the belt sensor? Also, I wet the the belt under running water where the contacts are, if you put the belt on dry it often does not have enough moisture for a signal.
                • EzioAuditoreE Offline
                  EzioAuditore Gold Members @MaxiPalle
                  Hi everybody. I will reuse this post not to open unnecessary new one. Do you know if S9b is compatible with Garmin’s HRM Pro? I have the HRM Run but this is no good since it is ANT+ so I want to get the Pro that offers 2 simultaneous BT and unlimited ANT+. I occasionally use fenix and do not want to miss the ‘running dynamics’ that Garmin offers. Want to use belt with the s9b cause the OHR is almost unusable for me 😞 When running the first minutes it locks on my cadence so it gives 50-60 beats more, then it somewhat stabilizes and when biking it goes too low (45 - 55 bpm which I only have when sleeping). Thank you and take care!
                    isazi Moderator @EzioAuditore
                    @hristijan-petreski the S9 connects to any Bluetooth HRM as far as I know.
                      EzioAuditore Gold Members @isazi
                      @isazi Thanks a lot. Will give it a try and post my feedback here for future references.
                        @hristijan-petreski I tested Polar, Wahoo, and Suunto in the past.
                        V 1 Reply Last reply Reply Quote 1
                        • V Offline
                          vicoongrou @isazi
                          @isazi said in S9 and HR belt:
                          And what was the best ? (For you)
                            isazi Moderator @vicoongrou
                            @vicoongrou there is no answer to this question, it depend on who you are and where you live. I currently have the Suunto belt and a Polar OH1.
                            • W Offline
                              wakarimasen Silver Members
                              I’ve connected my S9B to a Polar OH1 and a Suunto Smart belt - though not at the same time! Both worked ok after pairing and then selecting for the activity. I also switched off the wrist HR from the watch.
                              Suunto Race Titanium
                              Suunto Ambit3 Peak
                              Polar H10
                              Polar OH1
                              • cosme.costaC Offline
                                cosme.costa @wakarimasen
                                @wakarimasen If you are connected to an HR belt or armband you do not need to switch off the wrist HR in the watch. It is automatically disabled. In the GPS lock screen you will see that the Hr symbol has like a strap, when the watch uses the wrist HR the symbol is a plain heart.
                                What the watch doesn’t do is to switch between wrist and chest/armband HR. I mean, if you lock the GPS/HR with the OH1 switched off and then turn on the OH1 the watch is not going to use the OH1. You must turn it on before you go to the GPS/HR lock screen.
                                BTW @wakarimasen @isazi , a little bit of topic, but how is the battery life in your OH1? mine is lasting only around 5/6 hours and I’m thinking on contacting support.
                                BulkanB isaziI W 3 Replies Last reply Reply Quote 1
                                • BulkanB Offline
                                  Bulkan Moderator @cosme.costa
                                  @cosmecosta said in S9 and HR belt:
                                  Too short if is not very old.
                                  cosme.costaC 1 Reply Last reply Reply Quote 1
                                    isazi Moderator @cosme.costa
                                    I am not using it for very long activities, lately it has become my travel companion when I want to bring something compact in a trip. But I can do two back to back days with 4/5 hours if I remember correctly.
                                      cosme.costa @Bulkan
                                      @bulkan said in S9 and HR belt:
                                      Thanks @bulkan, it has less than a year, 11 months only. Definitely I will contact Polar support.
                                      inkognitoI 1 Reply Last reply Reply Quote 1
                                      • inkognitoI Offline
                                        inkognito Platinum Member @cosme.costa
                                        @cosmecosta Before you do, check that you have the latest firmware installed via Polar Flow or Polar Beat. You might also try to disable ANT+, maybe that helps a bit. Mine is ~ 14 months old and the battery can last 9+ hours.
                                        SV: fingers crossed :D
                                        • W Offline
                                          wakarimasen Silver Members @cosme.costa
                                          @cosmecosta I thought switching off the WHR might save a little battery life - I’m all about charging infrequently. 😉
                                          SO far as the OH1 is concerned, I used it on Sunday when fielding in a cricket game for 3 hours, and Polar Beat still says that the battery is ‘full!’
                                          Based on past experience, I would say it normally lasts longer than 5-6 hours, and I bought it 2019.
                                          Best regards,
                                          RoyM
                                          Suunto Ambit3 Peak
                                          Polar H10
                                          Polar OH1
                                            cosme.costa @inkognito
                                            @inkognito Thanks,
                                            I’m in the last FW, but I had ANT activated, I’ve just disabled it and I’ll see how the battery performs, if continues the same I’ll contact support.
                                            Thanks to everybody.
                                            W 1 Reply Last reply Reply Quote 1
