    Spartan Sport WHR Baro - GPS Accuracy "OK" - fix rate
    31 Posts 3 Posters 2.1k Views 4 Watching
    • zadowZ Offline
      zadow @Dimitrios Kanellopoulos
      @Dimitrios-Kanellopoulos said in Spartan Sport WHR Baro - GPS Accuracy "OK" - fix rate:
      @zadow Did you use navigation? What file is with the OK mode?
      Hi Dimi,
      No, Navigation was completely OFF. Even the Navigation display was off, not even breadcrumb mode. All three days was tracked with GPS set to OK. I did not change it. and I was not even changing it during the hiking. Mode OK all the time.
      Suunto Race
      Suunto Smart Sensor
      Wahoo Tickr FIT
      Hammerhead Karoo 2
      Swim Ride Run Rest Repeat
      • zadowZ Offline
        Did you use any ETA custom fields?
        Hmmm… you are asking - Did you use any ETA custom fields? - so yes, if I remember correctly, my custom Hiking mode contains ETA fields, just for case that I would need navigation.
        But still, navigation was completely off. IMHO, ETA field should not affect GPS accuracy, when navigation is off. If so, than it is clearly pointing to a bug in firmware…no?
        Suunto Race
        Suunto Smart Sensor
        Wahoo Tickr FIT
        Hammerhead Karoo 2
          Dimitrios Kanellopoulos Community Manager @zadow
          @zadow Ok cool. Which link is with Ok mode?
          • zadowZ Offline
            All three 🙂
            But take Day #2 and Day #3
            Day #1 contains a huge pause when we were sitting and eating in a Hut and I was also playing with wathces and setting a bit. So the last two days (#2 and #3) are best for any troubleshooting, I would say 🙂
            Thank you and have a nice day!
            Suunto Race
            Suunto Smart Sensor
            Wahoo Tickr FIT
            Hammerhead Karoo 2
              From a quick look it does not look like OK mode. SAmples are every ~1-5s
              • zadowZ Offline
                @Dimitrios-Kanellopoulos Exactly. And that is what I am referring to. I am more than 100% sure that GPS accuracy was set to OK. I checked that many times during tracking as I was noticing quick battery drain.
                I noticed this problem some time ago, I tried soft reset and then again, set it to OK. Still logging frequency is too high and definitely not 60 seconds. And that is the reason why I wanted to report is as a bug. I am not sure what more I should try to fix it, from the user perspective.
                Suunto Race
                Suunto Smart Sensor
                Wahoo Tickr FIT
                Hammerhead Karoo 2
                  I am not sure now as well.
                  I need one more confirmation from you.
                  a) USe the same profile / settings and do a little walk more than 15minutes
                  b) use a default sport mode eg walking with the OK setting and do a walk of more than 15mins
                  Post here the results.
                  I might be able to create a case then
                  • zadowZ Offline
                    You mean same settings as I used on hiking trip, right?
                    Suunto Race
                    Suunto Smart Sensor
                    Wahoo Tickr FIT
                    Hammerhead Karoo 2
                      @zadow yes just to make sure it’s not a specific sport mode thingy
                      zadowZ 1 Reply Last reply Reply Quote 1
                      • zadowZ Offline
                        @Dimitrios-Kanellopoulos Problem solved 😎
                        I tested default walking activity with GPS set to OK and everything was correct. Then I deleted my custom hiking mode and recrected it again with exactly same settings. Et voila, it worked. Samples every 60 seconds. So, there must have been some quirk in my previous custom hiking mode. Now it works as expected and I am happy user again 🙂
                        Thanks and have a nice day!
                        Suunto Race
                        Suunto Smart Sensor
                        Wahoo Tickr FIT
                        Hammerhead Karoo 2
                          @zadow Great to hear so. Strange though.
                          If there is any issue again please post here so we can check it !
                          Have a super duper nice day
