    GPS Signal lost
    33 Posts 6 Posters 2.1k Views 6 Watching
      freeheeler @Frederic
      @Frederic
      not sure if ambit and s9 work the same but this is the instruction for ambit:
      Force firmware update for Windows
      1. Connect the watch to the computer.
      2. Right click on the Moveslink2 icon (M) on the system tray and choose “Force Firmware Update”.
        Frederic Bronze Member @zhang965
        @zhang965 But Galileo is for EU right ? I am in the US (Colorado)
        My Suunto Workflow
        MyTourbook - First Steps
        Questions or bugs ?
          zhang965
          but you mentioned tour du mont blanc?
            @Frederic
            GPS is us military, glonass russia, galileo European civil… but all work global
              @zhang965 Yep, I was there in vacation and was sad to struggle EVERY day for my watch to find signals. The interesting thing is that it almost always lost signal around 10am. Not sure why…
              My Suunto Workflow
              Questions or bugs ?
                zhang965 @Frederic
                @Frederic
                I’d show you my story,
                My s9b GPS with galileo could work great, on a 400m track, it can be precious about +/- 1meter.
                but only in the morning, my afternoon running never gets the same results.
                F freeheelerF 2 Replies Last reply Reply Quote 0
                  @zhang965 Wow, +/-1 meter!
                  I will see when I try with GLONASS. I actually don’t really care that much for very accurate precision as longs as I have a GPS track somewhat accurate
                  My Suunto Workflow
                  Questions or bugs ?
                    freeheeler @zhang965
                    @zhang965
                    the early bird gets the worm…
                    do more receivers reduce accuracy?
                    do you know?
                    it would be horrible for big marathons
                      zhang965 @freeheeler
                      @TELE-HO the paris-vervailles has 21 000 runners, it didn’t seems impact the gps precision
                        tomahawk5000
                        Hello everyone,
                        I’m interested how works GPS on GOOD and OK profile. I know that those profiles are less accuracy than BEST one.
                        Today I had small Sunday walk and I turned on walk on my watch
                        Here is that route:
                        https://www.suunto.com/move/tomaszbury250/5eca82a34870d468b511cf92
                        There is around 50% of my route with quite good track and 50% which is straight line.
                        How long that straight line could be? When the watch will find my GPS?
                        Kind regards,
                        Tomek
                        Suunto 9 baro + Android
                          isazi Moderator @tomahawk5000
                          @tomahawk5000 apparently you could not get a lock at some point, and you got it only after a while, thus the straight line. And because you are walking and not running, Fusedtrack does not work so the watch cannot “estimate” your track based on sensors.
                          To be honest, unless you need more than 24h of battery for a single activity, there is no point in changing GPS settings to something worse than the best profile.
                            Brad_Olwin Moderator @tomahawk5000
                            @tomahawk5000 I do comparisons from time to time. The only way is with two watches. I wore my S7 and two S9b watches one on Performance and one on Endurance. Data are below and if I did not tell you which was Endurance vs. Performance you would have a hard time guessing. This is a hill climb I did twice so each track from each watch will have 4 lines.
                            T 1 Reply Last reply Reply Quote 4
                              tomahawk5000 @Brad_Olwin
                              @Brad_Olwin ok but what dose it means? I should go faster?
                              Kind regards,
                              Tomek
