    Direct drive indoor trainer
    57 Posts 14 Posters 4.5k Views 13 Watching
      Likarnik Bronze Member
      I just got direct drive indoor trainer. Is there a possibility to connect all data to my Suunto 9? I have Suunto bike pod, and my trainer tracks power, speed, cadence. If I connect it as a power pod it shows only power data, cadence is measured from Suunto bike pod, but there is no speed data (as I don’t have back wheel). Did someone manage to have all the data on the watch? I was thinking to connect indoor trainer to PC with ANT+, so I could track workout on watch and still use Zwift. Any ideas?
      Tnx
        No one uses Suunto 9 for indoor cycling?
        freeheelerF N 2 Replies Last reply Reply Quote 0
        • M Online
          Mi_chael Bronze Member
          No, I use Wahoo Roam with Kickr Core.
            freeheeler @Likarnik
            @Likarnik
            I use S9B for outdoor sports only.
            in the gym I only look at the HR screen few times just to have a slight info
              Shrek3k
              Not your topic, but I use S9 indoor, too.
              But only on a treadmill and not at all with any bike (etc), and as all data that I want to have / can have use the usual sensors (including Stryd) I have no issues … or an idea to help.
              using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling mostly through the northern german "wilderness"
              OS - Android 15/Pixel Pro 7
                mbga9pgf Bronze Member
                One suggestion would be to get an ant+ to Bluetooth bridge. This converts Ant+ to BLE protocol. You then connect this to your laptop and use the other direct BLE to your watch. Or vice versa.
                I prefer the direct connection to the laptop as it prevents dropouts and digital flats! There are a few HRM that do both BLE and Ant+ and most power meters, stages is the one I use, do both too.
                Hope this helps
                  Thanks for all replies, when I had ‘dumb’ trainer there was no problem, just connected to bike pod and I had all the data (except power) from back wheel. Now I connect my smart trainer via ANT+ to computer, and to S9B via Bluetooth, it is just the speed (and distance) data that I am missing (no back wheel). I suppose watch thinks that it will get speed/distance/cadence from bike pod, not from indoor trainer (paired as power pod). I have all the data just need to put it together somehow 🙂
                  isaziI M 2 Replies Last reply Reply Quote 0
                  • isaziI Online
                    isazi Moderator @Likarnik
                    @Likarnik can you connect the trainer both as power and bike pod?
                    • N Offline
                      nseslija Bronze Member @Likarnik
                      @Likarnik I am using s9b for indoor cycling, but with ‘dumb’ Tacx trainer…and as you said ‘with no problem’…
                      Ambit 2S
                      Ambit 3 Peak
                      Suunto 9 baro
                      Suunto Vertical Ti Solar
                        Likarnik Bronze Member @isazi
                        @isazi sadly no, I tried, removed all paired devices, search for bike pod and indoor trainer was not found. When searching for power pod, trainer is found in second 😮 I don’t know how watch separate bike vs power pod…
                        @nseslija hehe, smarter the equpment, more problem. Now my wife (she got me the trainer) thinks that she got me a bad gift because of my data OCD 😞
                          mbga9pgf Bronze Member @Likarnik
                          @Likarnik I measure power on my watch via ANT+ to BLE and the bike outputs power and cadence to Zwift to adjust the turbo resistance. Do get some connection dropouts but you cant connect the power meter to multiple devices unfortunately using BLE alone. Its why I am tempted by Garmin as they do ANT+ support on the Fenix. I didn’t like Garmin connect though as Movescount I thought was much better…
                            Dwartus
                            Hello all,
                            I’m in same situation as @Likarnik , I’ve a trainer Kickr Core with Suunto Ambit 2.
                            Ambit 2 is only ANT+, no BlueTooth function.
                            I can paired the power meter of the trainer with Ambit2 but not the RPM and speed meter (named Bike POD for Suunto) comes from trainer too.
                            I have also a bike POD on my bike, the Ambit2 is able to paired the power meter of Kickr Core and also the Suunto bike POD on my bike (bike without rear wheel due to direct trainer), this configuration is working.
                            I also removed the Suunto bike POD of my bike and of the Ambit2, then try to paired only the RPM and speed of the Kickr Core (Bike POD on watch), but not possible !!
                            I have also try the same scenario with Spartan watch (of my wife), this is the same situation, power meter is possible but not the RPM and speed (bike POD).
                            Spartan is working with BlueTooth only.
                            Could you support me ??
                            Thanks a lot
                            Regards
                              Dwartus
                              Nobody use a smart trainer with Sunto watch ?
                                johann.fuehrer Bronze Member @Dwartus
                                @Dwartus I did try with my a Tacx Neo, does not work: neither With Ambit 2, Ambit 3 or S9 BARO. There is always some data missing (ether RPM or Power). I have used two other brands, they do work (V800 + Vantage, Fenix 6). 😞
                                https://forum.suunto.com/post/56516
                                • BulkanB Offline
                                  Bulkan Moderator
                                  I use Zwift, I gave up to use the Suunto connected to trainer, which is possible without a problem, but I want the data of zwift in Suunto app.
                                  So I use Rungap app (iOS) to transfer the fit file to suunto app, now it transfers the fitfile with the info of ascend/descend and distance of zwift, which it didn’t math with the distances and ascend of the Suunto connected to the trainer, this is not a problem of Suunto, at this point the virtual cycling and running doesn’t get very well with watches. In some brands (in s7 you have an app for that) you can broadcasts your pulse but the distance and elevation never math.
                                  Sometimes I want to track in the watch the hours so I use the ant+ to the trainer and the bluetooth connection to the Suunto watch, but later I delete the workout in suunto app and upload the fitfile.
                                    Dwartus
                                    @johann-fuehrer Thanks for your answer. In fact I use an Ambit2, I also have an Spartan (my wife).
                                    With Ambit2 and Spartan, as you confirmed, I can’t received/paired the speed data from my smart trainer (Kickr Core). I can receive power data (by paire Power Pod) and receive RPM data (by paire Cadence POD). I tried to receive speed by using Bike POD, but not possible.
                                    From my side I tried with Garmin 520+ of a friend, and magic it’s work very well (power, RPM and speed), I also can set the gearbox, in short it’s great !
                                    So, you confirm that is not possible with Suunto watch (either Ambit2, nor Spartan, nor Suunto9 Baro) to receive speed data from a smart trainer ??
                                    I will read your topic link, thanks !!
                                    @Bulkan I also can connect my Suunto to smart trainer, but not receive speed data. I want to have speed data (even if doesn’t match with the virtual ride due to descend speed and so on…), because I want to have a total distance of the activity in Suunto App. My real tracking is done on Suunto App (before on the perfect Movescount).
                                    I will have a look on the Rungap app (iOS), does it exist also website ??
                                    I’m thinking to buy Suunto9 Baro since 6montsh, but due to this “issue” compare to Garmin, and the end of Movescount, I will thnik again 😊
                                    Thank you
                                      @Dwartus said in Direct drive indoor trainer:
                                      I have tried really hard for getting A2, A3 and S9B work, I did not make it for all data (Speed, Distance, Cadence, Power) on this watches. For Spartan I cannot tell as I had one but could not try with my trainer, as I sold it for the S9B.
                                      BR
                                        Dwartus
                                        @johann-fuehrer I have read your other topic.
                                        Your smart trainer Tacx Neo is able to send Power, Cadence and Speed by Bluetooth ?
                                        Your S9Baro is able to catch Cadence and Speed from the Tacx Neo by using paire a « Bike POD » ?
                                          Dimitrios Kanellopoulos Community Manager @Bulkan
                                          @Bulkan didn’t run gap fix those issues?
                                          D BulkanB 2 Replies Last reply Reply Quote 0
                                            Dwartus @Dimitrios Kanellopoulos
                                            @Dimitrios-Kanellopoulos
                                            Hello Dimitrios,
                                            Does Rungap has an issue to sync activity from Zwift to Suunto App ??
