    Suunto 9 Baro - deteriorating battery life
    35 Posts 10 Posters 2.3k Views 10 Watching
    • JoohlinJ Offline
      Joohlin
      Since I updated my Suunto 9 Baro about three weeks ago the battery life has deteriorated. Before the updated I could use the watch every day 24/7 and work out three - four times a week and the battery would last for ca seven days. After the updated the battery only lasts about 4-5 days with out having done any work outs as I got a severe cold the day after making the updated.
      Has any one else experienced the same or is it just my watch that is giving up?
      /Johan
        GingerBeardMan Bronze Member @Joohlin
        @Joohlin Someone did suggest running the battery completely flat before charging it after the update but I think its a case of “more features less battery life”. I have been told that the battery life was not because of a big battery but from efficient use of power so I suspect that battery use during activities is unlikely to change but the first beat features will cause faster battery drainage.
        JoohlinJ 1 Reply Last reply Reply Quote 1
        • JoohlinJ Offline
          Joohlin @GingerBeardMan
          @GingerBeardMan Thanks for the answer.
          So one should expect to charge every three our four days from now on?
            My estimate is that with 24/7 hour battery tracking, standby backlight on, and syncing to SA the watch consumes about 1% of battery per hour, which is less than 5 days total. That isn’t counting any activities.
              I did an experiment and got to five days with only a short activitity (without GPS), and still had battery for a sixth day left.
                freeheeler @isazi
                I could imagine it is premature wear on @silentvoyager 's watch
                  A Former User @freeheeler
                  @TELE-HO said in Suunto 9 Baro - deteriorating battery life:
                  I doubt that. Until recently I was charging my watch only once every two weeks. I see a high consumption like that only when 24/7 monitoring is on and syncing to SA.
                  And you know what, I turned all features off last night when the watch battery was 51%. This morning after a run with GPS the battery is still 49% which means the background consumption was less than 1% for the entire night.
                    freeheeler @Guest
                    @silentvoyager
                    ok so you can at least exclude this.
                    I’m just draining my battery to recalibrate it amd then I’ll also go off for 24/7 HR again and see how this changes batterylife.
                      @Joohlin Sorry for the late reply.
                      Pretty much, unless you disable the 24h tracking.
                      • Bogdan1921B Offline
                        Bogdan1921 Silver Members Bronze Member
                        It seems that in the last time (probably after the last update), the battery of my watch (Suunto 9 Baro) drain faster.
                        100% - 07.04. - 16:20
                        79% - 08.04. - 16:40
                        59% - 09.04. - 16:23
                        41% - 10.04. - 16:38
                        16% - 11.04. - 17:23
                        0% - 12.04. - 12:00
                        (No activity in this period)
                        I brough this watch in November 2018, and at the beggining the battery leastead almost 7 days (without activities).
                        From the beggining until now I keep the same settings:
                        Backlight Automatic
                        Standby - On
                        Brightness - 40%
                        24/7 tracking - On
                        Sleep tracking On
                        Notifications On
                        So if any setting was changed, what is wrong?
                        Many thanks
                        Bogdan
                        Suunto Race
                        Polar H10
                        Iphone 14 Pro
                        Suunto 9 Baro [sold]
                          isazi Moderator @Bogdan1921
                          @Chindris-Bogdan battery consumption increased slightly after the fall 2019 update that brought body battery and other Firstbeat features.
                            Thank you for answer!
                            It’s possible maybe to have a better optimization of the battery with the new firstbeat features and maybe with other features that will come?
                            Best,
                            Bogdan
                            Suunto Race
                            Polar H10
                            Iphone 14 Pro
                              @Chindris-Bogdan we’ll see what future brings us. So far I am OK with charging my watch every calendar week, exercising every day.
                              Of course battery life is never enough for some of us, and if the watch could last for two weeks I probably would want three 😄
                              freeheelerF Bogdan1921B 2 Replies Last reply Reply Quote 2
                                freeheeler @isazi
                                @isazi said in Suunto 9 Baro - deteriorating battery life:
                                4 😁
                                  Bogdan1921 Silver Members Bronze Member @isazi
                                  And when it should be 1 week, in reality there are only 4 days and so on…I don’t want two weeks, three or four. It’s just annoying that from seven days now I’m at four.
                                  Cheers
                                  Suunto Race
                                  Polar H10
                                  Iphone 14 Pro
                                    @Chindris-Bogdan 4 days without any exercise?
                                      Yes, in this period it’s impossible to make exercises…
                                      Suunto Race
                                      Polar H10
                                      Iphone 14 Pro
                                        @Chindris-Bogdan well 4 days without any exercise seems too little. Have you tried a soft reset already?
                                          Yes, I’ve tried, but with the same result.
                                          From my older post, to see my settings:
                                          0% - 12.04. - 12:00
                                          Backlight Automatic
                                          Standby - On
                                          Brightness - 40%
                                          24/7 tracking - On
                                          Sleep tracking On
                                          Notifications On
                                          What is different in your settings?
                                          Suunto Race
                                          Polar H10
                                          Iphone 14 Pro
                                          isaziI A 3 Replies Last reply Reply Quote 0
                                          • GNZ ctG Offline
                                            GNZ ct
                                            Try standby backlight “off”
