Suunto app does not sync activities to movescount (web based)
32 Posts 7 Posters 6.3k Views 7 Watching
    Tyll Voigt
    Hello!
    I am using the new suunto app with my spartan sport without any bigger issues so far. Since I deleted the movescount app from my phone and only use the suunto app, no activities are getting synced between the suunto app and the web based movescount.
    How can I fix this?
    Thanks a lot!
    M 1 Reply Last reply 28 Jan 2020, 12:03 Reply Quote 0
      Maryn Silver Members @Tyll Voigt
      @Tyll-Voigt Suunto App doesn’t sync with Movescount.
        Tyll Voigt
        Does this mean I can only see the activities on my phone and not anywhere on my laptop???
        M J 2 Replies Last reply 28 Jan 2020, 12:06 Reply Quote 0
          @Tyll-Voigt yes…but Hey! you can use a very good web based analyze tools like:
          https://quantified-self.io/home
          or Runalyze.
          You can set up autosync in SunntoApp for Runalyze or directly in web service for QS.
            Tyll Voigt
            Ok great, I will try that. Seems a bit weird that Suunto is launching a new app which is not compatible with their only online (desktop) tool…
            F 1 Reply Last reply 28 Jan 2020, 12:12 Reply Quote 2
              jseguir Bronze Member @Tyll Voigt
              @Tyll-Voigt you can see your activities in https://www.sports-tracker.com/dashboard
              Suunto Spartan Sport blue 2.8.32
              Suunto App (Android) 4.35.2 beta
              Suunto Ambit 3 Peak 2.4.17
              Footpod: Stryd & Milestone Pod
              From lost to the river…
              F 1 Reply Last reply 28 Jan 2020, 12:15 Reply Quote 1
                Fenr1r @Tyll Voigt
                @Tyll-Voigt That online tool is for the chop: https://www.suunto.com/transition.
                  freeheeler @jseguir
                  @jseguir
                  but sports-tracker is not the web for SA.
                  I 1 Reply Last reply 28 Jan 2020, 15:15 Reply Quote 4
                  • I Offline
                    isazi Moderator @freeheeler
                    @TELE-HO to be fair, neither are QS, Runalyze, and any other service.
                    F 1 Reply Last reply 28 Jan 2020, 15:21 Reply Quote 1
                      freeheeler @isazi
                      BUT they don’t sync without you knowing it and on the other hand they show data that is really really useful 🙂
                      I 1 Reply Last reply 28 Jan 2020, 15:23 Reply Quote 0
                      • I Offline
                        @TELE-HO the fact that ST has your activities without you even having to ask for that, shows that, in practice, the two systems are very close to each other. Now, we may find that ST is pretty useless for us, but it is kind of a fact that if you don’t want to enable any third party service, but still be able to see your activities on the web, ST is the only actual solution.
                        F 1 Reply Last reply 28 Jan 2020, 15:37 Reply Quote 1
                          Fenr1r @isazi
                          @isazi If I don’t want ST to have my data, can I prevent that?
                          F 1 Reply Last reply 28 Jan 2020, 15:41 Reply Quote 1
                            freeheeler @Fenr1r
                            @Fenr1r
                            I don’t think it is possible as the database is appearently the same…
                            F 1 Reply Last reply 28 Jan 2020, 16:00 Reply Quote 0
                              Fenr1r @freeheeler
                              @TELE-HO Thanks. Although it’s not a civilisation-ending issue, I’m not very happy about that. Do you know if client use of Movescount already lets Amer move his/her data wherever the company pleases within its operations or if that common ST/SA database requires extra permissions linked to use of SA? Was there mention of ST in the SA EULA (assuming there is such a thing)?
                              If the App can work happily off-line, perhaps syncing with its backend (in the shape of that joint ST db) should also be optional. If folk want to restrict their activities to the external services the closure of MC.com may encourage (full-screen, etc.), why should anything have to go to ST at all?
                              F I 2 Replies Last reply 28 Jan 2020, 17:11 Reply Quote 2
                                freeheeler @Fenr1r
                                @Fenr1r said in Suunto app does not sync activities to movescount (web based):
                                I’m not sure, I could move my data to SA completely, but not sure about customers with Ambits and other watches… if this is what you mean?
                                true, it’s not the end of the world, but it’s not nice and clean either
                                F 1 Reply Last reply 28 Jan 2020, 17:23 Reply Quote 1
                                  Fenr1r @freeheeler
                                  @TELE-HO Thanks. Actually, I almost mean the reverse. I mean keeping my movement data off the SA server altogether, if that is to be shared with another service (ST) which is of no use to me. If I am only going to use SA as an import/export bridge to external (non-Amer) services, I don’t need (or want) them to have my activities on any db.
                                  D 1 Reply Last reply 28 Jan 2020, 18:12 Reply Quote 1
                                    Dimitrios Kanellopoulos Community Manager @Fenr1r
                                    @Fenr1r I think in theory one could do that using the SA Android / SL
                                    Turn on offline mode sync get the SML .
                                    F 1 Reply Last reply 28 Jan 2020, 18:16 Reply Quote 1
                                      Fenr1r @Dimitrios Kanellopoulos
                                      @Dimitrios-Kanellopoulos Interesting. And in Apple+PC world? Intercept the SML in the offlined PC’s file system? Does SL chuck one out to await syncing like good ol’ ML?
                                      D 1 Reply Last reply 28 Jan 2020, 18:20 Reply Quote 0
                                        @Fenr1r it stores the SML files in a folder /Users/myusername/Library/Application Support/Suuntolink as zip, .gz, .json (depending on the watch)
                                        Needs to be “enabled to sync with MC”
                                        Those files QS can parse 😉
                                        And theoretically you can / could pass them to any other app converted , or run QS even locally in an emulator (with some coding effort).
                                        Long time ago I wanted my ‘raw’ data 🙂
                                        Btw there is a tool that can pull those without the SL being installed for some more advanced users.
                                        F 1 Reply Last reply 28 Jan 2020, 18:25 Reply Quote 4
                                          @Dimitrios-Kanellopoulos said in Suunto app does not sync activities to movescount (web based):
                                          Accessing the file system on the watch directly? I am highly intrigued and sufficiently advanced as to tie my own laces (on a good day). Where might I find this tool?
                                          D 2 Replies Last reply 28 Jan 2020, 18:52 Reply Quote 1
                                          20 out of 32
                                            consent.not_received
