    How to create and upload POIs to my Suunto 9
    4 Posts 3 Posters 739 Views 3 Watching
    • LarsStoL Offline
      LarsSto
      Hi
      I´m new to Suunto, so sorry for what is probably a stupid question, but the following makes me confused. I want to know how to create and upload POIs to my Suunto 9. This is easy enough with a route:
      Export a gpx-file with a route > upload to phone > open Suunto App on phone > Map > Import Route (gpx).
      But what about POIs?
      I would expect this was done the same way as importing gpx-files in the Suunto App, but as far as I can see, you can import routes, but not POIs in the Suunto App. Is that really correct?
      As far as I find, Suunto Support says I should use Movescount (even though I read everywhere that Suunto App is the future…). OK, so I register in Movescount and follow the instructions in the Suunto Support article, until I come to the point “Connect your watch to Movescount”. The Suunto 9 is not on the list of supported watches (see photo below)! Now what?
      Appreciate if someone can help me get a little smarter on this…
      Best regards
      Lars
        sartoric Moderator @LarsSto
        Hi @LarsSto
        Please try the forum search function before opening a new post as this topic has already been discussed (and still is) as in not yet available from Suunto App
        https://forum.suunto.com/search?term=suunto app poi&in=titlesposts
        To connect to Movescount you need suuntolink. S9 access to MC was added after it was released for this kind of workaround as it was supposed to be paired to SA only.
        SVTS - 2.50.28
        • LitchiMonsterL Offline
          LitchiMonster Bronze Member
          Please see this post, and vote it up for visibility!
          https://forum.suunto.com/topic/94/ability-to-create-and-sync-poi?_=1580904796503
          Suunto 9 Baro black
            sartoric Moderator @LitchiMonster
            @LitchiMonster
            I don’t think we need to vote anymore as POI should be released soon.
            Should be, afair, the spring release.
            I’m closing this to avoid duplicates
            use one of the existing threads to keep discussing
            SVTS - 2.50.28
