    Ongoing problems with altitude
    11 Posts 5 Posters 985 Views 5 Watching
    • reggerR Offline
      regger Bronze Member
      Since one week my Suunto Baro 9 provides totally wrong ascent / descent information. The workout at the screenshot was ascent only until the break and a descent only after the break (white = current height). I’ve also added the air pressure at sea level (green).
      Also the GPS track is shown on my screenshot.
      What could be the problem? Defect barometer?
        Have you ever cleaned it ?
        SVTS - 2.50.28
        Suunto App Android 6.8.9 beta
        • reggerR Offline
          Cleaned the watch? Not really. I’ve it on often during showering 😉
          sartoricS Václav KrálV 2 Replies Last reply Reply Quote 0
            sartoric Moderator @regger
            @regger
            So first try to clean the baro with warm water (soak it a bit) and mild soap, rinse it, shake it a little bit and let it dry.
            Then, if you see no changes, you can try to brush it with a soft (really soft) toothbrush while rinsing with warm water.
            If nothing change… ask suunto support 🙂
            SVTS - 2.50.28
            • reggerR Offline
              Thanks for the hint! Will try.
                @regger
                If you search the forum you’ll find some other discussions about it
                Search for “fridge test” too
                SVTS - 2.50.28
                reggerR 1 Reply Last reply Reply Quote 1
                • Václav KrálV Offline
                  Václav Král @regger
                  @regger I cleaned senzor yesterday, because pressure and height changed 3x times per minute on same place and during last activity there was in reality about 120 m ascent / descent and watch showed me 1500 m 😵 . I just left my watch in water with me during bathing in bath (with soap and under 50 degrees temperature) and this helped 👍
                  I was swimming in first part of last year for 2 - 3 times per week, so this cleaning wasn’t neccesary, but this year I wasn’t swim and sensor was totally confused. Now all is working fine 🙂
                  Polar A360, Polar M600, Polar M430
                  Suunto Spartan Trainer, Suunto Spartan WHR Baro
                  Suunto 9 Baro
                  Coros Apex Pro
                  Google Pixel 2
                  reggerR 1 Reply Last reply Reply Quote 2
                  • reggerR Offline
                    regger Bronze Member @sartoric
                    @sartoric said in Ongoing problems with altitude:
                    @regger
                    I tried this. No success. So my Suunto 9 goes back, warranty is still void. Made a exercise with my old Ambit 2 - oh i miss the reliability of the ascent / descent meter calculation - just around 1% deviation.
                    • reggerR Offline
                      regger Bronze Member @Václav Král
                      @Václav-Král said in Ongoing problems with altitude:
                        stevena Bronze Member
                        Wearing watches that are not very waterproof (200m) in the shower is asking for moisture to get into them. Not sure if it is because of the temperature changes and pressure changes that occur in them or because of the soap.
                          Brad_Olwin Moderator @regger
                          @regger @regger said in Ongoing problems with altitude:
                          @regger
                          Sorry to hear this, the S9 can be great, here is a comparison with A3P and S9 and S7 for Hill Intervals last Thursday. All three are essentially identical and you can see the FusedAlti engage for S9 and S7.
                          Vector/T6c/Vertical 2 Ti
