    Problem with altimeter s9b
    15 Posts 6 Posters 618 Views 6 Watching
    • Giulio Dall'OstoG Offline
      Giulio Dall'Osto
      I have a problem with my S9b. In section “outdoor” when I select “auto adjuste altitude” the Watch goes in loop and don’t found the altitude. Is It normal?
        What do you exactly mean? Your watch should tell you that you can close the menu and it’ll notify you when it has a new altitude.
        Giulio Dall'OstoG 1 Reply Last reply Reply Quote 0
          Giulio Dall'Osto @isazi
          @isazi It seems that the process never found the altitude!
            isazi Moderator @Giulio Dall'Osto
            @Giulio-Dall-Osto are you outside? It needs GPS, good GPS, for something like 5-10 minutes to work.
              @isazi and if I don’t start the process of auto adjust, the process doesn’t work in background. Right?
              Václav KrálV isaziI 2 Replies Last reply Reply Quote 0
              • Václav KrálV Offline
                Václav Král @Giulio Dall'Osto
                @Giulio-Dall-Osto This is backgroud process.
                Polar A360, Polar M600, Polar M430
                Suunto Spartan Trainer, Suunto Spartan WHR Baro
                Suunto 9 Baro
                Coros Apex Pro
                Google Pixel 2
                  @Giulio-Dall-Osto you have to start the process, then it’ll work in the background.
                  • Saketo NemoS Offline
                    Saketo Nemo Moderator
                    it is almost useless to do this, unless you have a very incorrect altitude as given on the watchface, and in this case I advise you to manually set the altitude, where known.
                    Doing it before an activity is not needed, it will take care of fusedAlti to recover the right altitude once the activity has started
                    Giulio Dall'OstoG 1 Reply Last reply Reply Quote 1
                      Giulio Dall'Osto @Saketo Nemo
                      @Saketo-Nemo @isazi ok thanks. I don’t notice wrong altitude. But, when I started this process(auto adjuste altitude), It seems It never found the altitude.
                        at the cost of being repetitive: were you outdoors with good visibility of the sky?
                          @Saketo-Nemo yes! In any case the process seems don’t found the altitude
                            sartoric Moderator @Giulio Dall'Osto
                            @Giulio-Dall-Osto
                            As it is a background process, you’ll never receive any confirmation message.
                            In fact what it does is to kick in fusedalti (afair) so it keeps “correcting” altitude for a while.
                            Of course you need a good GPS signal
                            SVTS - 2.40.38
                            Suunto App Android 6.1.4 beta
                              isazi Moderator @sartoric
                              @sartoric on S9 you get a notification when it’s done.
                                sartoric Moderator @isazi
                                oohhh … what a magic !
                                SVTS - 2.40.38
                                • Cuba1hrC Offline
                                  Cuba1hr
                                  🙂 I have done it after the reset (when s9b stopped responding) and on altitude of 250m it missed about +20 meters what was earlier showing (before restart). It was off more than 50 meters before auto adjust. I don’t know exact altitude in single meter so I let it auto adjust altitude.
                                  It normalized few days later, after 2 walk activities.
