    Battery LIfe
    450 Posts 54 Posters 87.7k Views 55 Watching
    • Saketo NemoS Offline
      Saketo Nemo Moderator
      @Federico-Ormesani, here we are just trying to help. We can have different opinions, right or wrong, not take it badly.
      Allow me a little addition on the barometer. As you will have seen from my print screen, there are applications that consume much less, simply choose others. As you know, among other things, it is a third-party app it is only useful in watch mode, during the activity it is Suunto wear that provides you with the data, it does not seem to me to be even essential, or not so much to judge if a watch is good or not.
      The fact that Suunto 7 is the reference of autonomy among the smart watches wear os, I think is a fact, then it is up to each of us to use it and set it according to the needs of autonomy. If, on balance, autonomy no longer meets your needs, return the product.
      In addition, I invite you without any controversy to reflect on the position you are holding, opposite to anyone else in this 3d.
        A Former User @Federico Ormesani
        @Federico-Ormesani said in Battery LIfešŸ˜•
        Well then it is stated that it is possible to have certain ā€œseverl options via google playā€ features
        Let me tell you a story. Once upon a time, when the grass was greener, skies higher, and the watch complications new and fresh, there were two weather related ones in a small cozy shack of Google App Store. The first complication was from AccuWeather and the second from the Weather Channel. Since I was a dedicated user of the latter, I naturally chose theirs. Even though all they provided was this complication only, not even a tiny stinky app to back it up. After a few hours of thoroughly enjoying up-to-date temps and weather conditions right on my watch screen no less, I discovered to my horror the big fat LG watch was almost out of battery.
        Sounds familiar?
        Well, I checked the battery usage and there was the Weather Channel complication, prominently sitting at the top of the list. Guzzling volts like there’s no manana. Bad complication, bad! To the trash it went, kicking and screaming, promptly replaced with AccuWeather for the time being.
        I haven’t had this issue ever again. End of story.
        Just because several options are available via Google Play, doesn’t mean all of them are equally good or advisable. Sometimes bugs happen even to an otherwise decent app. Sometimes your particular settings result in a much higher drain than usual. It’s up to you as a user to analyze the trade-offs and make a decision.
        • JANTIKAINENJ Offline
          JANTIKAINEN Bronze Member
          Something very strange is going on with my S7 battery consumption.
          It has had a massive battery drain 3 nights in a row.
          First night the battery drain was 40%
          Second night it was 45%
          And last night the battery drain was a whopping 69% (it died at 5 am so I put it on charger)
          Took the watch from charger at 8.50 am and 1 hour after the battery is already down 7% and estimated battery life is 11 hours
          Any advices on this issue?
          besides the ā€˜native’ apps, I’m using
          -Sleep as Android
          -Wear Messages (appfour)
          -Wear Photos
          -Wear Calendar
          -Wear Mail
          -Ghostracer
          I’ve booted both my S7 and my phone.
          Samsung Galaxy S24
          Suunto Race Titanium
            isazi Moderator @JANTIKAINEN
            @JANTIKAINEN can you try to activate ā€œairplane modeā€ when you go to bed, and see if that changes something?
            JANTIKAINENJ 1 Reply Last reply Reply Quote 0
              JANTIKAINEN Bronze Member @isazi
              @isazi Yes I will test but doesn’t it prevent sending HR information to Sleep as Android?
              Samsung Galaxy S24
                @JANTIKAINEN I don’t know either, I’ve got my S7 just two days ago and I’m still at the stage where heart rate data is not recorded at all šŸ˜„
                  Brad_Olwin Moderator @isazi
                  @isazi Are on iOS or Android? @JANTIKAINEN I do not have that much depletion from Bluetooth, are there updates happening? I would check app updates. Another possibility is that the phone sleeps and the watch is attempting to connect often. Are there apps that may be attempting to get data from WearOS?
                    isazi Moderator @Brad_Olwin
                    @Brad_Olwin I’m on Android. Today I deleted and then reinstalled fit and now it’s working in the background.
                    • aeroildA Offline
                      aeroild Bronze Member
                      With our interest in battery life on the Suunto 7, I wonder how complicated it would be for Suunto to add e.g. ā€œ%-battery usedā€ in the sports activity report?
                      • Kai LiuK Offline
                        Kai Liu Bronze Member @Federico Ormesani
                        @Federico-Ormesani
                        Same issue here. I turned airplane mode on, selected hiking as the sport. Battery goes from 100% to 28% in 4 hour.
                        See battery stat:
                        https://i.ibb.co/YQpYqrf/Screenshot-20200608-165527.png
                        S7, S9P, Vertical Solar / boxing, skiing, hiking, running
                        luca760101L Saketo NemoS Federico OrmesaniF 3 Replies Last reply Reply Quote 1
                        • luca760101L Offline
                          luca760101 @Kai Liu
                          @Kai-Liu
                          I had the same experience, I also sent my S7 back to Suunto, but they say that the watch has no defects …
                            Saketo Nemo Moderator @Kai Liu
                            @Kai-Liu
                            Did you use poles during your excursion?
                            I ask why, for what has been my experience, their use leads to a much greater activation of the screen compared to simple walking or running.
                            vr2udtV luca760101L Kai LiuK 3 Replies Last reply Reply Quote 1
                            • vr2udtV Offline
                              vr2udt Bronze Member @Saketo Nemo
                              @Saketo-Nemo maybe we should turn off all the gestures for such activity?
                                luca760101 @Saketo Nemo
                                @Saketo-Nemo
                                Yes, this winter with skimo activity and now sometimes with trail Running. I know this problem. I hope Suunto resolve in next upgrade.
                                • Kai LiuK Offline
                                  Kai Liu Bronze Member @Saketo Nemo
                                  @Saketo-Nemo I do but watch is on my left hand and pole is on my right hand … so it should not matter?
                                  @vr2udt Even if you turn off gestures, it still on when you are in sport mode.
                                    nope. One pole, on the other side of the wristh, i think does not count
                                      I don’t do long activities with the S7, but hiking I should get around 6h at the moment (in recent weeks I have seen 25% consumption for a 1:30 walk in the park).
                                      • Holby19H Offline
                                        Holby19 Bronze Member
                                        I ran for 90 min this morning and S7 battery went from 98% to 83%. Pretty good I think. Tilt to wake was on. Trail running activity.
                                        • Kai LiuK Offline
                                          I factory reset the watch, and on airplane mode a 4.5 hours hike took battery from 90% to 28%, better than before but still not good …
                                            Brad_Olwin Moderator @Kai Liu
                                            @Kai-Liu I routinely get 6-6.5h trail running and would probably get longer hiking. In March with the firmware you are running my watch went 7h with 18% battery left when I stopped my race. If you turn on Airplane mode and have tilt to wake, do not use maps a lot, some is ok and do not turn screen on all the time you should get 7-8h battery life during exercise. Longer for biking and likely longer for hiking to as HR is usually lower. If you are routinely doing 8h-12h activities this watch is not likely a good choice. However, I know that Suunto will be improving the watch, I just don’t know how long or exactly what improvements will come, and I couldn’t say if I did know.
                                            EgikaE isaziI 2 Replies Last reply Reply Quote 1
