S7 and S9 on same phone
10 Posts 4 Posters 415 Views 4 Watching
    BKtoo Bronze Member
    any tricks for using the S7 and S9 with the Suunto app on the same phone? Any possibility of using HR belt with S7?
      Egika Platinum Member
      you can pair both and then in the app switch from one watch to the other by “forgetting” it and connecting the other one.
      Works pretty well.
      You can use a BT heart rate belt with the S7, just at the moment not with the native Suunto watch app.
      Other apps like Ghostrunner can use external sensors without problems.
      If you can wear your watch on your wrist, the new integrated HR sensor works pretty well though.
      Run Lime
      B 1 Reply Last reply 8 Apr 2020, 16:09 Reply Quote 2
        BKtoo Bronze Member @Egika
        @Egika thanks for good advice. Do you mean disconnection and connection under this symbol in the Suunto app? 627C9217-D7FA-4CEF-BC28-067EA6375C80.jpeg
        B 1 Reply Last reply 8 Apr 2020, 16:28 Reply Quote 0
          Brad_Olwin Moderator @BKtoo
          @BKtoo Yes but do not unpair the watch, just forget. You can then easily swap watches. I swap up to 5 different watches with one phone and one SA😵
          B 1 Reply Last reply 8 Apr 2020, 17:18 Reply Quote 3
            BKtoo Bronze Member @Brad_Olwin
            @Brad_Olwin you mean forget watch in the Suunto app? I did it in settings-BTsettings om the phone. And now I can’t connect my S9. Any trick?
            E 1 Reply Last reply 8 Apr 2020, 19:10 Reply Quote 0
              tomahawk5000
              Hi guys and hope about with connect one S9 to 2 phones? Is it possible to receive notification from 2 phones?
              Kind regards,
              Tomek
              Suunto 9 baro + Android
              E 1 Reply Last reply 8 Apr 2020, 19:12 Reply Quote 0
                Egika Platinum Member @BKtoo
                @BKtoo said in S7 and S9 on same phone:
                Don’t touch the phone BT connection.
                Just do it in the app only where Brad indicated.
                Both watches stay in the list of known devices of the phone.
                Run Lime
                B B 2 Replies Last reply 9 Apr 2020, 00:54 Reply Quote 2
                  Egika Platinum Member @tomahawk5000
                  @tomahawk5000 not possible
                  S9 can handle only one connection per type.
                  One phone, one foot pod, one HR belt etc…
                  It has been asked before to be able to manage multiple devices in the watch…
                  Run Lime
                    Brad_Olwin Moderator @Egika
                    @Egika Thanks Egika!
                      @Egika thanks! It solved the problem👍6FCA2278-35BE-4333-8ECB-CAAC62FB39B3.png
                      1 out of 10
                        consent.not_received
