    Suunto 9 - Cadance and Speed Sensor Pair Querry
    10 Posts 8 Posters 610 Views 8 Watching
    • Fatih KaleF Offline
      Fatih Kale
      Hi Everyone,
      Like in most of the world, I am stucked at home as well and I can’t train outdoors for long time :(.
      I switced to home trainer. It’s a basic one and does not have any sensor on it so to make the most out of my indoor riding I need some data.
      I want to get a cadance and speed sensor to pair with my watch.
      Do you have any suggestions?
      Unfortunately Suunto bike Sensor is not available in Turkey.
      Do Polar, Garmin or Decathlon C&S sensors pair with S9? Can I use it for Zwift?
      I know most of us here mainly focus on Trail Running. If there are anybody with this experience, I appreciate 🙂
      Suunto 9 Baro
        tomahawk5000
        I guess all Bluetooth devices can be paired as my Polar H7.
        Kind regards,
        Tomek
        Suunto 9 baro + Android
          I would also guess that any proper Bluetooth sensor would work, but cannot test that right now.
            Fatih Kale
            There is bike pod option on connectivity menu. Does bike pod mean speed and cadance sensors together?
            Suunto 9 Baro
              Dimitrios Kanellopoulos Community Manager @Fatih Kale
              @Fatih-Kale yes
              • N Offline
                nseslija Bronze Member @Fatih Kale
                @Fatih-Kale Hi, I am using Bontrager DuoTrap, it is designed for Trek frames, and iti is working great with S9B. I think any BT speed and cadence sensor will do the job. I am using it with Zwift also.
                Ambit 2S
                Ambit 3 Peak
                Suunto 9 baro
                Suunto Vertical Ti Solar
                  Mi_chael Bronze Member
                  Yes, only combo sensor.
                    Michał Muszyński
                    It must be a sensor that supports both cadence and speed. A sensor consisting of two devices will not work with S9. S9 can only support one device. In this case you will have a speed or cadence
                    • P Offline
                      pend1
                      Am using the Wahoo sensors … they work flawlessly!
                        Fatih Kale
                        Thank you everyone. This was all the information I needed.
                        Suunto 9 Baro
