    Display setting bug?
    5 Posts 3 Posters 412 Views 3 Watching
    • macdavM Offline
      macdav Bronze Member
      I set Heat map as a watch face and have in Settings - Dipslay - Always-on screen turned off.
      But after finishing activity with this watch face automatically Display is turned on and I have to manually turned it off. I think it is only in this watch face. Is it OK?
        Brad_Olwin Moderator @macdav
        @macdav The best settings to have for battery savings is power save tilt on, tilt to wake off and touch to wake as you prefer. The settings for the display are distinct in Suunto Wear app and the watch.
        Christian BittencourtC 1 Reply Last reply Reply Quote 0
        • Christian BittencourtC Offline
          Christian Bittencourt @Brad_Olwin
          @Brad_Olwin I have these preferred settings on my watch but after a minute or some minutes this is changed back to “wake by tilt” by it self!!! I change it back to “power saver by tilt” but it won’t stay this way. No help from Sunnto support, they didn’t even record my case. Any suggestions?
            Brad_Olwin Moderator @Christian Bittencourt
            @Christian-Bittencourt In Settings/Gestures what is on and what is off? Mine are Powersaver tilt on and Touch-to-wake on, that is it.
            Christian BittencourtC 1 Reply Last reply Reply Quote 1
              @Brad_Olwin These are the ones I have turned on. But the watch will by it self set “wake up by tilt”. Seams like a software bug and it drives me crazy to have to uncheck it over and over again.
