    Problems with transferring data to Movescount
    14 Posts 5 Posters 838 Views 5 Watching
    • Filip KošárF Offline
      Filip Košár
      Hey,
      I’m struggling to transfer data from the watch to Movcountcount. I have 6 moves in my watch, but I can’t see any of these moves on Movescount. I tried to reconnect them several times, but the problem persists. I don’t know what the problem is.
      • zvonejanZ Offline
        zvonejan Bronze Member
        which watch? Do you use SA also?
        • reggerR Offline
          regger Bronze Member
          Same Problem here since today…it was working until today but now I dont see moves in Movescount and no Sync to Strava
          • reggerR Offline
            Suunto 9 and I use SA also
            • zvonejanZ Offline
              Where do you edit sport modes. In movescount or in SA?
              • reggerR Offline
                Movescount
                • reggerR Offline
                  Also Suunto App Sync to Strava of todays Workout doesnt work
                  • reggerR Offline
                    • cannot download FIT file in Suunto App from this Workout (for other Workouts its possible)
                      stevena Bronze Member
                      Same problem, started working again after an hour. Unrelated, since I started getting adverts for the suunto app movescount has been starting to work worse and worse lately. especially through the mobile app, usually it won’t sync. Could this be a move from suunto to “nudge” us to the suunto app? #conspiracy theories 🙂
                      • reggerR Offline
                        in the meantime my move has been synced
                          Filip Košár
                          Spartan sport and I use SA too. But it’s working again.
                            Mff73 @Filip Košár
                            @Filip-Košár
                            @regger
                            Glad it works now, but I am a bit perplex here.
                            You both use SA, and your issue was not to see your moves in Movescount, and now it works. 🤔
                            SA doesn’t sync to Movescount.
                            zvonejanZ reggerR 2 Replies Last reply Reply Quote 0
                            • zvonejanZ Offline
                              zvonejan Bronze Member @Mff73
                              @Mff73
                              Works fine until You edit sport modes in SA. I use that option for one year, Sync with BT with SA and with cable to Movescount
                              • reggerR Offline
                                regger Bronze Member @Mff73
                                @Mff73 said in Problems with transferring data to Movescount:
                                @Filip-Košár
                                @regger
                                Seems that SA to Strava didn’t sync. I also connect my watch with the cable and Suuntolink to have the moves also in Movescount. And this move has been transferred with a delay also.
