    Bad max. speed
    19 Posts 7 Posters 1.1k Views 6 Watching
    • DurriD Offline
      Durri
      Hi Can you tell me why S9baro wrote such a high max speed on SA? (from GPS) The graph is around 49Km /h and on STRAVA app is correct too.![alt text](![image url](image urlScreenshot_20200623_120915_com.strava.jpg ))
      https://www.suunto.com/move/jurajkovacs/5ef0f2fad31f6d08aae16438
      Suunto Race Titanium, Suunto 9 Baro Titanium, Polar V800, Vostok Anchar Europe Titanium, Hoka One One, Focus Atlas 6.8, Rose Pro SL, Giant Roam 2
      • EgikaE Online
        Egika Platinum Member @Durri
        @Durri speed spikes can happen due to issues with GPS reception. If there is signal reflection or very bad reception etc, there can be a glitch. You need to tell more details of this activity, like sport mode, environment, conditions etc for a better analysis.
        DurriD 1 Reply Last reply Reply Quote 1
          Water doesn’t help GPS at all 😁
          Suunto App Android 6.3.3 beta
          • DurriD Offline
            Durri @Egika
            @Egika It was a bike ride, I have already inserted a link to the activity. But I still don’t know where the maximum speed came from, when it’s not even on the graph in the application.
            DurriD 1 Reply Last reply Reply Quote 0
            • DurriD Offline
              Durri @Durri
              @Durri Where’s the crazy max speed? My real max.speed ​​was like the one on the chart.Screenshot_20200623_130247_com.stt.android.suunto.jpg Screenshot_20200623_130611_com.stt.android.suunto.jpg
                freeheeler @Durri
                @Durri
                if you upload your activity to quantified-self.io you will most likely see the speed spike as QS shows the unfiltered and ugly truth 😜
                I once had 200km/h on my roadbike… take this, Froome 😂
                DurriD 1 Reply Last reply Reply Quote 2
                • DurriD Offline
                  Durri @freeheeler
                  @TELE-HO The error must have occurred somewhere in the application…Screenshot_20200623_133237_com.android.chrome.jpg
                    Mff73 @Durri
                    @Durri said in Bad max. speed:
                    More likely the “error” happens in the watch.
                    As said, maybe a GPS glitch, causes a spike in speed, and other softwares are filtering it.
                    PS : your link seems not to work, does this activity share publicly, for us to see ?
                    • inkognitoI Offline
                      inkognito Platinum Member
                      Have you used any external bike speed sensor? This happened to me many times when I was using one. When I stopped and then continued riding, the speed often went nuts in the first seconds… I described this in detail to Suunto, they promised to look at it and I think that nothing was done ever since 😄 Now I’m using just the GPS and everything works fine.
                      Edit: Sorry, I now noticed you mentioned GPS only. So, forget this 😄
                      SV: fingers crossed :D
                      • DurriD Offline
                        Durri @Mff73
                        @Mff73 Ohhh yes, I made a mistake. I saved the .fit folder from the exercise and deleted the exercise in the Suunto application. I wanted to sync the workout again because it is still stored in the watch. But with the new sync, the workout didn’t transfer to the app. Can you advise me how to do it?
                          Dimitrios Kanellopoulos Community Manager @Durri
                          @Durri
                          1. Delete the app.
                          2. Unpair the watch from the BT settings of the phone.
                          3. Reboot the phone
                          4. Make sure it’s forgotten by checking again the BT settings of the phone. (Some phones need restart to really forget the connection).
                          5. Install, pair and sync
                          • DurriD Offline
                            Durri @Dimitrios Kanellopoulos
                            @Dimitrios-Kanellopoulos let’s do it 🙂
                              @Durri Keep in mind to never delete it from the watch.
                              2 more tips since (I think) you are new.
                              1. Updating the watch erases the data on it. IT will still keep summaries but no actual data. So never update without sincing activities first.
                              2. When max memory is reached the old ones are also cleaned to make space.
                              3. To check if an activity has the data (or is gone) on the watch logbook you should have charts etc. If only the distance and pace eg are there then the activity is empty (has only the summaries)
                                Dimitrios Kanellopoulos Community Manager @Dimitrios Kanellopoulos
                                @Dimitrios-Kanellopoulos hmmm those where 3
                                • DurriD Offline
                                  @Dimitrios-Kanellopoulos everything is fine, it succeeded, but it did not affect the wrong max. speed - it’s like before
                                  https://www.suunto.com/move/jurajkovacs/5ef1f65224216c3cf87b3263
                                  sartoricS Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 1
                                    sartoric Moderator @Durri
                                    @Durri
                                    app version ?
                                    • DurriD Offline
                                      Durri @sartoric
                                      @sartoric 4.22.3
                                        @Durri it wont if the max speed.
                                        I had this as well with my walk yesterday. It can happen if GPS is “lost” even for a few secs (so you dont get the warning) and you are moving. It happens imo rarerly. I would look at that point on the map if there are any straight lines
                                        • DurriD Offline
                                          @Dimitrios-Kanellopoulos ok, Thanks for help 🙂
