    Ambit2 - without offline-configurator electronic waste?
    16 Posts 8 Posters 795 Views 8 Watching
      suolaf
      Hello, everyone,
      i am the owner of an Ambit2 and was actually very satisfied with the clock until now, except for the fact that there was and is no offline desktop software to configure the clock (apps, body weight, navigation routes, navigation POIs, etc.).
      When I bought the watch at that time, I was already angry about this circumstance, because I got dependent on Suuntu and their rarely stupid online configurator.
      Exactly the fact that Suuntu only offered this stupid online movescount solution to configure the watch now becomes a big problem.
      Why many forists here only complain about the missing data export from the Ambit2 to Movescount I don’t quite understand, because there are several offline solutions for that I can live with.
      But if I can’t adjust the apps and settings in Ambit2 anymore, the clock becomes useless.
      The hardware is and will remain excellent, but the lack of offline software to configure the clock now turns it into electronic waste.
      How does Suuntu deal with this situation? Will there be an offline solution after all?
      MarynM EgikaE A 3 Replies Last reply Reply Quote 0
      • MarynM Offline
        Maryn Silver Members @suolaf
        @suolaf you can still use movescount to configure it
          Egika Platinum Member @suolaf
          @suolaf afaik Movescount has never been an offline software. Movescount is relying on data in the cloud that stores your watch settings, apps and moves.
          The situation has not changed still you got the watch, has it?
          Run Lime
            amasidlover Bronze Member @suolaf
            @suolaf see https://www.suunto.com/en-gb/Content-pages/digital-service-transition/ - the Nov. 2019 update…
            “Suunto Movescount.com (web service): Our web service will continue to evolve in 2020. We will no longer call it Movescount and its role in our services will be to enable key functionality (including watch settings, routes and sport mode customization) for Ambit (1, 2 and 3) and Traverse family watches only. We are planning these web-based updates for the second half of 2020 and will keep everyone updated on the changes coming. No changes are happening right away.”
            So you should still be able to change settings for the forseeable future; although I do agree with the principle - all manufacturers of devices that can be configured with an online service should also provide a mechanism to configure it without the online service.
              @suolaf said in Ambit2 - without offline-configurator electronic waste?:
              So, based on what you said, you already bought electronic waste from the beginning. Isn’t it ?
              Out of curiosity, didn’t you gather some info before buying ?
              SVTS - 2.40.38
              Suunto App Android 5.3.5 beta
                margusl
                Part part of the issue here seems to be lack of information or inconsistency of transition updates from Suunto.
                Suuntolink update that enables support for all Ambits (1/2/3) and introduces workflow that will probably be really close to the final one was released over 2 months ago. How many current Ambit users know about this?
                Now compare this imaginary figure with number of Ambit users who think that Movescount will be shut down, rendering their watches semi-useless.
                @suolaf , you can replace your existing Moveslink2 with Suuntolink today and you don’t have to think about any of this in (few?) upcoming years. Assuming you are OK with your activities ending up in Suunto App instead of Movescount. If it this is not the case, just keep using Moveslink2 as long as possible and then move over to Suuntolink. Movescount.com will still be the place for changing sports modes, settings and routes / pois, most likely apps too (Suuntolink syncs those just fine). Even when Movescount loses everything related to activity-analysis and will be renamed or redesigned.
                https://www.suunto.com/Support/faq-articles/suuntolink/new-suuntolink-update/?setcountry=en
                I don’t see Suunto opting for any offline solution for Ambit-line, they just want to keep maintenance and dev-hours at minimum. Though open-source community might come up with something usable, at some point.
                  suolaf
                  As long as I can configure the clock, we’re good.
                  The information I’ve been reading for the past few days said otherwise.
                  I’m going to take a look at Suuntulink tonight.
                  Thank you for the ample information 🙂
                    suolaf @sartoric
                    @sartoric At the time I bought the watch, there were no comparably good alternatives, so I accepted the online disadvantage with a bad conscience.
                      suolaf @Egika
                      @Egika Yeah, I still have that watch (since 2015).
                        suolaf
                        Suuntulink only allows firmware updates.
                        Programming apps/training programs with the appropriate display for the watch and uploading them to the watch is not possible with Suuntulink.
                        This functionality is important for me because I use my own calculation formulas.
                        Hopefully this functionality will continue to exist, as you claim here.
                        J lexterm77L 2 Replies Last reply Reply Quote 0
                        • J Online
                          jsuarez Bronze Member @suolaf
                          Then you’re basically screwed. It seems apps will not return to Suunto app or suuntolink.
                          • lexterm77L Offline
                            lexterm77 Bronze Member @suolaf
                            You do all programming and customization on Movescount website, then you download latest SuuntoLink and connect to it to your both Movescount and Suunto App accounts, When you connect A2 it will download all your custom apps, custom sport screens POI and Routes from Movescount to your watch.
                            When you record all your activities by connecting your watch too SuuntoLink watch will upload it to Suunto App platform.
                              sartoric Moderator @jsuarez
                              @jsuarez
                              Correct, but wrong 😁
                              Suuntolink never had “app” configurator or any kind of customization tool.
                              “Ambit apps” won’t (very probably) never be added to SA, but based on Suunto’s info, Ambit users will still have a MC like online platform to use such functionalities.
                              SVTS - 2.40.38
                              lexterm77L 1 Reply Last reply Reply Quote 1
                                lexterm77 Bronze Member @sartoric
                                @sartoric said in Ambit2 - without offline-configurator electronic waste?:
                                @jsuarez
                                I have bunch of apps I cannot erase from my MC, remove button does not work. Never checked if they actually work or not.
                                  margusl @lexterm77
                                  @lexterm77 said in Ambit2 - without offline-configurator electronic waste?:
                                  Because those apps are still in use?
                                  This also applies to your public apps, to remove those, you’ll first need to track down all its users and somehow force them to remove it from their sport modes. Deleting unused private apps works just fine.
                                    lexterm77 Bronze Member @margusl
                                    @margusl said in Ambit2 - without offline-configurator electronic waste?:
                                    I was able to keep a small number of apps before, If I wasn’t using them remove button would work so my app list would be more tidy. None if them are being used on a watch on any screens but I still cannot remove them.
