    Movescount problem...
    11 Posts 4 Posters 444 Views 4 Watching
    • P Offline
      puhecfan
      Im asking for help.
      I registered on the page it works ok.
      Uploaded by Suunto link works ok watch has software 2.11.38 suunto 9 bar.
      However, there is no data on the movescunt that the clock is connected.
      Tried on three computers the connection does not work.
      AAP oK works on the mobile phone.
        According to what I’ve read, activities synced with Suuntolink don’t go anymore to Movescount, but to the Suunto App database.
        • H Offline
          halajos Bronze Member @isazi
          @isazi said in Movescount problem...:
          As far as I know, that’s true for the Ambit series atm. I could sync my SSU to MC via Suuntolink a couple of days ago. I received a Suuntolink update just today, so that may change the behavior, I don’t know.
            isazi Moderator @halajos
            @halajos alright, you haven’t done the migration of your history to SA right? @puhecfan seems to be able to see his/her activities on the mobile phone, so maybe he/she switched to SA.
            • H Offline
              Right, I stick with MC as long as it’s up. Waiting to see what boils out…
              • P Offline
                puhecfan
                @halajos said in Movescount problem...:
                Any suggestion whether I need a watch which is a new update to the new software.
                What if I can’t connect the clock, to the suunto programon
                • P Offline
                  puhecfan
                  Can I use the suunto app to create a navigation route?
                    isazi Moderator @puhecfan
                    @puhecfan what are you using, Movescount or the Suunto App?
                    • P Offline
                      puhecfan @isazi
                      @isazi I would like to make a way to navigate, but I don’t know which app to use to work on suunto 9.
                      • V Offline
                        vicoongrou @puhecfan
                        @puhecfan you can use SuuntoApp to create a new route.
                        And after just do a sync between your watch and your phone
                        If you don’t like the phone “format”, you can use the Web site SportTracker.
                        By the way, SA allows you to import any .gpx file
                        • P Offline
                          puhecfan
                          I found on aap thanks for everything …
