    Suunto 5 battery replace
    4 Posts 4 Posters 1.3k Views 4 Watching
    • Deniss PeļņaD Offline
      Deniss Peļņa
      Hi there,
      Is it possible to change the battery in Suunto 5/9?
      What is the number of battery charge cycles supported?
        Egika Platinum Member
        battery can only be replaced by the Suunto service center.
        there is no hard number of charging cycles after wich the battery will be dead.
        Battery life depends on so many things like temperature, charging current (which is low in the watches), age, cycles, etc.
        the Sunnto 5/9 are pretty new on the market, if not defective by default, they will last for years (based on charging like every few days).
        • suzzloS Offline
          suzzlo Moderator
          There is a procedure explained in the forum for battery calibration (you will need to search). I will try this in order to be sure that the battery is defective
          BR
          Garmin: FR745, Edge 530
          SA topics:
          • Saketo NemoS Offline
            Saketo Nemo Moderator
            Simply go to 100% and then to 0% and then back to 100%
