    S9 Baro Pre-purchase questions - navigation and displayed data
    31 Posts 10 Posters 2.4k Views 10 Watching
      sartoric Moderator @kabzior
      @kabzior said in S9 Baro Pre-purchase questions - navigation and displayed data:
      And if you have more points on your track, the watch shows the time/distance to the closest one, and then after reaching it, it switches to the next point?
      Correct
      It is a really PITA that one can not import a route with points in it or edit the route that is already in SA 😕
      afair this should be available sometime in the future
      Suunto App Android 6.3.3 beta
      kabziorK 1 Reply Last reply Reply Quote 0
      • General_WittG Offline
        General_Witt @kabzior
        Yes, correct.
        Waypoints are even visible in the route map watchface, that is the one you’ll keep on the watch while hiking, provided you keep the scale under 500 meters.
        As far as I know they’re working on it and in general to make the process of route creation and waypoints addition smoother and simpler.
        It’s still involuted at the moment but somewhat usable.
        I considered Fenix at the beginning, but firstly I already have a house mortgage 😉
        Fenix 6 series is objectively a better watch but it’s not 2 years old like the S9 and I’d not value it 3 times the S9, not even 2 times.
        Take the battery duration, S9 is still on the Fenix 6 level and the display of the S9 is brighter and more readable in direct sunlight imho. Altitude reading is also better on the S9.
        I wanted the altitude profile
        That is done very well in the S9.
        The altimetric profile is simple to read, it shows sea level altitude and the remaining ascent of your route.
        Unfortunately not the remaining descent (just the remaining ascent) when you’re going down.
        Garmin Instinct
        S9 is not even comparable to the Instinct.
        Sapphire glass, better materials, better battery, better display (the one in the Instinct is so small), better mountaneering functionalities, overall S9 is a tier1 sportwatch, while Instinct is a tier2.
        At first everyone advised me against Suunto
        A lot of people come here on the forum when they have some issue with the watch, and rightfully so, but the problems described are often exaggerated. If you like to be flooded with data, some bugs and a lot of niche features you go Garmin, if you like fewer useful features and a reliable watch you go Suunto.
        kabziorK 2 Replies Last reply Reply Quote 0
        • kabziorK Offline
          kabzior Bronze Member @sartoric
          @sartoric said in S9 Baro Pre-purchase questions - navigation and displayed data:
          Correct
          @General_Witt said in S9 Baro Pre-purchase questions - navigation and displayed data:
          Yes, correct.
          It’s like Christmas in August 😉
          So, I find process of creating new route or editing freshly imported one on SA very easy and comfortable, so it would be just enough for me to be able to edit tracks saved in SA.
          But I found some post here on forum that one can send route with WP to SA from QS and it works… well, it works indeed, WP are there… nevertheless I think just editing would be enough for me, here are my results if this experiment:
          https://forum.suunto.com/topic/4682/import-gpx-to-sa-with-waypoints/12?_=1597509783219
          Oh, did not notice sapphire… nice.
          And forgot to mention, I was considering Instinct Solar, not regular Instinct. Not that solar is such a breakthrough, but in this version they added new GPS unit, new HR sensor and power management, so to do Instincts justice it now has better battery than S9B (30h without solar / 38h with solar vs 25h). But it’s all now water under the bridge, S9B should be here on Tue 🙂
          • kabziorK Offline
            kabzior Bronze Member @General_Witt
            OK, so the watch is here, so far I’m delighted. I do the first tests, as long as walking around the city can be called test 🙂
            I have some rookie questions:
            1. The POIs that can be seen on the map and that can be displayed on the watch with ETA/ETE data, can one somehow see their list in the navigation mode (in the sense of how many are left and what is their order)?
            2. I understand that one can have max 4 screens that can be customized in SA (the last of which is always a map). And the additional fifth screen? Shows altitude profile?
            3. Is it possible NOT to lock the touch screen in activity mode? Firstly, it would be more convenient for me to scroll the screens right / left as needed, not only in one direction with the middle button, and secondly, I could activate the backlight (because I do not want the auto mode).
            4. Does the POI-reaching notification in the form of vibration and/or sound depend on vibrations and sounds enabled for other actions? I don’t want vibration when pressing buttons, but I do want vibration when reaching POI.
            And finally I would like to sincerely thank everyone who contributed to this thread, thus convincing me to buy this watch model. Praise you, it was a very good choice! 🙂
            kabziorK Brad_OlwinB 2 Replies Last reply Reply Quote 3
            • kabziorK Offline
              kabzior Bronze Member @kabzior
              Cannot edit any more, 3rd found (custom battery modes) and 4th found in settings.
                Brad_Olwin Moderator @kabzior
                1. This can be done for waypoints, don’t confuse with POI, which is a different thing. If you have a route loaded with waypoints you will see these in the map. The navigation will tell you how far to the next waypoint at the start and at each waypoint you will get the distance to the next but it is not displayed all the time, only as a popup.
                2. If you have a route loaded you will get the route altitude profile, which I find very useful, this will show the profile, the elevation and the remaining elevation gain on your route.
                3. You can set a custom battery mode to your liking and allow the screen touch to be responsive. I personally keep the screen touch off as I don’t find sweaty fingers very precise and don’t want sleeves or rain affecting the screen.
                4. In settings you can distinguish between buttons, alerts and alarms for vibration and tones.
                • kabziorK Offline
                  kabzior Bronze Member @Brad_Olwin
                  @Brad_Olwin said in S9 Baro Pre-purchase questions - navigation and displayed data:
                  Yes, WP not POI, my mistake. I have a route with WP, they are displayed on my map, they are (or rather there is, because it applies to just one, the closest one) also on one of the screens where watch si showing me distance and ETE to that closest one. 100m before reaching next WP I get a notification. So far everything great. My question is: can I somehow check how many WP are left on this route? Some list of those WP?
                  Yes, just as I tought, thank you for confirmation, this will be very useful indeed… just now I’m in a completely flat city so could not properly test it and was not sure what it is 😉
                    @kabzior So far no, you cannot check the waypoints other than zooming in or out on the route, which gives you approximate distances as you can see the waypoints on the route loaded in the watch.
                    • kabziorK Offline
                      Just for the record, thing I discovered today - once you have touchscreen activated during activity you can tap on the altimetric profile to change between remaining ascent/descent 🙂
                      General_WittG 1 Reply Last reply Reply Quote 3
                        Waaaaaat?!?
                        Going to try it tomorrow.
                          Egika Platinum Member @General_Witt
                          @General_Witt yeah, it is in the manual. Sometimes it helps reading it 😉
