    Suunto 7 won't charge.
    8 Posts 4 Posters 1.5k Views
    • Holby19H Offline
      Holby19 Bronze Member
      I put my s7 in the charger last night. Battery was at 40% ish. When I woke up the watch was in responsive. Screen is black won’t turn on. Nothing happens when I put back on charger. Any ideas.
        Brad_Olwin Moderator @Holby19
        @Holby19 leave it on the charger and hold the upper left button down for 60s. It may not have charged.
        Holby19H 1 Reply Last reply Reply Quote 0
        • Holby19H Offline
          Holby19 Bronze Member @Brad_Olwin
          @Brad_Olwin that did it. Seems like the charger has trouble connecting. Or maybe the human has trouble connecting the charger.
            isazi Moderator @Holby19
            @Holby19 not often, but a couple of times it happened that I thought the cable was properly attached to the watch, but it wasn’t, or I moved it after and it disconnected enough to not charge.
              @Holby19 said in Suunto 7 won't charge.:
              My cable is very touchy and I have to check to make sure the watch is charging.
              luca760101L 1 Reply Last reply Reply Quote 1
              • luca760101L Offline
                luca760101 @Brad_Olwin
                @Brad_Olwin
                my expectation: if the S7 discharges completely you must first connect it to the charging den for at least 30 minutes and then turn it back on, but disconnected from the cable, press the top left button for more than 12 seconds.
                  Brad_Olwin Moderator @luca760101
                  @luca760101 said in Suunto 7 won't charge.:
                  @Brad_Olwin
                  When my watch dies during exercise, it typically takes only a minute or less for the watch to show a charge icon after attaching to the cable. Once sufficient charge is available the watch will automatically reboot. The reboot happens within 5 min.
                  luca760101L 1 Reply Last reply Reply Quote 0
                    @Brad_Olwin
                    why doesn’t this happen in my S7? I can only turn it back on if I conclude the procedure I described earlier. So does this mean that our S7, although updated to the latest firmware, are not all the same? I begin to understand little with this watch
