    Problems with Altimeter
    4 Posts 4 Posters 886 Views 4 Watching
      SeifertM
      Hi Community!
      I have Little Problems with my height measurement. Yesterday i was on the Top of a Mountain at 1569m. My Suunto 9 works Perfect.
      Only at Home the measurement is wrong by 20-30 Meters. I habe entered the height of my village manually. I know That the GPS in my house is Not the Best but it work until 4 days Ago.
      I also restarted the watch.
      Has anyone a thanks!
        Brad_Olwin Moderator @SeifertM
        @SeifertM Changes in barometric pressure will affect altitude in watch mode. You can go to the Altitude screen and long press the middle button, Select AutoAdust and the altitude will be corrected. You need to be outside so a GPS fix can be obtained.
        • JorckiJ Offline
          Jorcki
          My Suunto 9 Baro just got replaced because a problem showing totally wrong altitudes during activities (-40m even though the real altitude was about 5m) but also wrong altitudes in the home screen mode. Usually after setting the reference altitude manually, the altitude immediately started rising or lowering by itself.
          According to Suunto service the problem was somekind of a leak etc. that had damaged the watch.
          • Stefan KerstingS Offline
            Stefan Kersting @Jorcki
            @Jorcki what kind of leak?
