    Wishlist for a future Suunto 7 firmware
    142 Posts 40 Posters 25.7k Views 40 Watching
    • BulkanB Offline
      Bulkan Moderator @Egika
      @Egika if the s9 would had notifications without sound I could wear the s9 in the office 😃
      So is not in the s9 all.
        Brad_Olwin Moderator @Bulkan
        @Bulkan It does, there is vibration. I miss the vibration while running sometimes but it always wakes me up as an alarm and when in the office it is quite noticeable. I do not have my sound turned on at all for the S9
        • JorgeFDJ Offline
          JorgeFD @Egika
          @Egika said in Wishlist for a future Suunto 7 firmware:
          there are quite a lot low power watch faces out there in the play store
          ey! do you have a list or something of watch faces tha full support low power as suunto’s watchsfaces do?
            Egika Platinum Member @JorgeFD
            @jorgefd78 search for ā€œ3100 watch facesā€ in the play store.
            That already has some that support the low power standby screen.
            • aeroildA Offline
              aeroild Bronze Member
              I testet the navigation from the last update on a new route today. I really like the map based navigation! This being a new route with lot’s of intersections, I had to tilt the watch to wake the navigation screen a lot. The screen takes a sec to wake and the navigation another sec to update. Many times I just needed to check that the route still was following the trail I was on and not turning to another trail in an intersection. For checking this, a simple navigation screen without map data like the one on the Suunto 5 or 9 would do. So to make a long story short, my wish for a future update is a simple navigation screen running on the battery saving co-processor. And maybe a touch of the screen could wake up the navigation with full mapdata.
              Fenr1rF Jamie BGJ makzamM 3 Replies Last reply Reply Quote 1
              • Fenr1rF Offline
                Fenr1r @aeroild
                @aeroild said in Wishlist for a future Suunto 7 firmware:
                The grass is always greener. Read on down a bit from there for a hybrid view.
                  Jamie BG Bronze Member @aeroild
                  @aeroild I also quite like the Suunto 9 bearing direction screen; and sometimes I do think that we need what you describe, however I don’t think it would work on the low power processer.
                  I do think you can assist yourself by adding lots of waypoints/cross road/reference points etc can really help (also with off route notification coming sooner) as at least you get a warning ahead of any possible change in reoute, and perhaps don’t add them where you need to go straight.
                  If they allowed our own description to show that would solve a lot of our problem as you could use a code or just say left turn, straight through, left fork etc and would effectively provide what you need without making any major changes.
                  aeroildA 1 Reply Last reply Reply Quote 0
                  • makzamM Offline
                    makzam @aeroild
                    @aeroild excelent idea!!
                    • aeroildA Offline
                      aeroild Bronze Member @Jamie BG
                      @Jamie-BG I’m not a engineer or software developer so I don’t really have a clue. However, the watch is already tracking the positioning data and displaying such info as speed, time and distance in real time, so I don’t see why displaying a line and a breadcrumb trail would be that much more demanding on the coprocessor.
                        @aeroild - would have to check some of this. I know that map view it isn’t running on the low power core processor. Would need to check when in the data screen mode, but I have a feeling that when you get a waypoint notification it is waking the screen up out of its power save mode (which I could have misunderstood, but I think that means it is boosting out of low power core into normal cores). Which makes sense as more power etc is need to display the additional data the notification tag provides, rather than just changing some basic digital numbers like a digital watch…
                        • aeroildA Offline
                          @Jamie-BG I agree, a waypoint notification would wake up the main processor. Similar to when the Suunto 7 displays autolap info, then the watch uses the main processor. Displaying just the breadcrumb trail and the route will hopefully just require the coprocessor and not use anymore battery than the always-on sport display.
                          • Zab_55Z Offline
                            Zab_55
                            I would really like to see date in the basic black watch-face which appears with power saver tilt ON, or some kind of possibility to choose what is displayed in those two small circles (battery should be just fine in the upper part of display maybe ?) 😁
                              Jamie BG Bronze Member @Zab_55
                              @Zab_55 loads of watch faces allow this. Go in and adjust features of watch face.
                              Long press watch face, then press blue cog (if no blue cog available watch face can’t be adjusted). Settings will come up. Add/adjust complications to choose how many/what comes up. Adjust ambient screen (if available) - minimal normally means no complications, with full having dimmed complications in ambient mode.
                              Zab_55Z 1 Reply Last reply Reply Quote 0
                                Suunto tracking app on the watch weight training needs a major uplift as all it does is time and HR. Come on suunto, how about making something like what Google fit provides: automatic exercise detection picking up curls, sit ups, press Up etc with ability to change activity (if it gets it wrong), auto counting of reps and sets (with option to adjust rep count), ability to add weight lifting for each set, an adjustable rest timer with option to skip, ability to also manually enter a session, duration and HR monitoring in background with calorie used, epoc, PTE and recovery.
                                • Zab_55Z Offline
                                  Zab_55 @Jamie BG
                                  @Jamie-BG oh Gosh, how blind I am. I was wondering if I should write it here, because it must be somewhere in settings but I didn’t see it 😁 Thank you !
                                  • Fly RivieraF Offline
                                    Fly Riviera
                                    Hello:
                                    As far as I’ve seen:
                                    -To use bluetooth sensors (like BikePod, Garmin BSCM Gen3. Wahoo HR…)
                                    Fly RivieraF 1 Reply Last reply Reply Quote 2
                                      Fly Riviera @Fly Riviera
                                      @Fly-Riviera Adding: Heart Rate visual at Default Sphere. (damm, that does even an Amazfit Bip Lite, less than 50$!!!)
                                        Jamie BG Bronze Member @Fly Riviera
                                        @Fly-Riviera said in Wishlist for a future Suunto 7 firmware:
                                        Sorry - you have really lost me? What does heart rate visual at default sphere mean - care to explain?
                                        I know that the S7 does active HR zones on main tracking screen. You can also use the HR tile to take a HR reading at any time / and or go into google fit to get a reading at any time. You can also set Google fit to take 24/7HR reading which can then be viewed in tile or google fit.
                                        Fly RivieraF 1 Reply Last reply Reply Quote 3
                                          Fly Riviera @Jamie BG
                                          @Jamie-BG please, let me check! It’s our new sportwatch! šŸ™‚ Is there a livetrack / emergency feature at Suunto 7/app?
                                          Jamie BGJ 1 Reply Last reply Reply Quote 2
                                            meyton89
                                            I would like to see the watch being able to connect to turbo trainers. Or an app to connect to them.
