Battery mode issue
@zhang965 Go to battery settings, go to custom mode, set it to be 1:1 like performance mode (same settings as in performance mode but in custom). It should default to performance mode next time - at last this is how it works in S5.
This works on S9 too. I was also having this issue. Thanks
reporting those
@Dimitrios-Kanellopoulos don’t you think it’s related to the issue I had with S5 and “good” custom GPS quality?
@Łukasz-Szmigiel yes its the same Bug if i understand correctly.
I have now nagged a lot about this. Thanks
@Dimitrios-Kanellopoulos Is this issue solved or still going on? When I test my s9bt, It hasn’t been corrected yet. I had to delete sports profile with this issue and create new one.
@Soojong-Moon is this really a bug or normal behaviour ?
I have a sport mode where I enabled the display timeout setting under custom profile. I selected the profile and started the activity.
The next time I selected the sport mode, it automatically selected custom instead of performance. Even if I switched it to performance, it was only for that activity and the next one would select custom again.However, once I reverted the setting I did under the custom profile (display timeout), the performance profile became my default again. I also noticed that the estimation of hours wasn’t present next to the custom profile after the change.
@surfboomerang I didn’t tested with your scenario but I believe this is a bug. Battery mode should remember last selection and if I can change defaults only by complicated operation, it is not good UI.
This bug is still remaining
This is not considered a bug from Suunto till this battery mode feature is reworked.
@Dimitrios-Kanellopoulos said in Battery mode issue:
“Reworked”…intrigued!!
Z zhang965 referenced this topic on
