    Indoor rowing adding distance and av split?
    indoor rowing
    2 Posts 2 Posters 204 Views 2 Watching
      Danno
      Hi guys. Is it possible to edit the distance after doing an indoor rowing session? EG. I do about 7.5km but the watch records my movement on the slide and gives a distance of about 2km. It’s very annoying when uploading to strava and for my log. It would be great to be able to add average split and distance.
      • TonyGT Offline
        TonyG Silver Members
        Yes, you can edit your distance in SA, but i don’t think this edit will transfer over to strava.
        If you have a Concept2 Machine then you could use their logbook to connect to strava that way it transfers the correct distance and a few other data points time/500m etc.
        If you do other sports which transfer to strava via SA and you decide to use the concept2 logbook to transfer your erg session, you will have to simply delete the transferred SA workout in strava which will be a duplicate of the concept2 session.
        Hope that make sense
        Edit: I should add I have the S9 but I would imagine the same data is editable in SA for the S5 Watches
