    S9 barometer problems
    69 Posts 11 Posters 9.5k Views 11 Watching
      freeheeler @fazel
      @fazel
      do you have this issue again or still?
      did you hear about the fridge test? despite that, it looks something is wrong…
      but could you please also share the alti profile of the watch and how it should look like?
        Dimitrios Kanellopoulos Community Manager @fazel
        @fazel do you have 2 fit files for me ?
        One from.the suunto
        One from.the Garmin ?
        fazelF 1 Reply Last reply Reply Quote 1
        • fazelF Offline
          fazel Bronze Member @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos Sure - PM or post here?
            @fazel as you please
            fazelF 1 Reply Last reply Reply Quote 0
            • fazelF Offline
              @Dimitrios-Kanellopoulos K - here you go.
              Suunto.fit Gramin.fit
              Hadn’t thought about loading them into DC Rainmaker’s Analyzer tool. This is what I see (blue is Suunto). They track well, Suunto is just consistently low.
                @fazel said in S9 barometer problems:
                2993 ft
                nothing is wrong here.
                Edge counts ascent even with ±1m bumps and affected by wind if it has a baro.
                Suunto 9 counts every ±3m
                Here are the charts
                Stats if I use 1m resolution for counting ascent
                Stats if I use 2-3m resoltuion / filter for counting ascent
                Using Runanalyze to check the elevation data
                I see as I said above that the 3m filtering is working the best. Take a good look below.
                Now lets see what other Digital Elevation Databases say
                Corrected to RaceEvelation service much much less ascent!
                Using STRM and other services for correcting the data:
                Take a good look please at the report. I did spend time todo this.
                My conclusion:
                Your Garmin records ascent every little bump that you take, more over it’s less realistic and out of coordination from most Digital Elevation services I used.
                Most of those services are aligned with your S9 baro as you can see.
                So your garmin overregisters ascent. Take this with a grain of salt but I live in NL. If I apply the same philosophy at some flats I ll be ascenting like 100+ meters that is not realistic. -+1m changes should not be reported as they do not really contribute to any effort the user should take into account for his performance lever nor data wise. That is counting noise basically.
                fazelF isaziI 2 Replies Last reply Reply Quote 9
                • fazelF Offline
                  @Dimitrios-Kanellopoulos Thank you for the time to put this together. I will read it over when I get to work 😉
                    @fazel a thing you can test your self.
                    Upload a ride to Runanalyze. There you can play with this (see screenshots)
                      isazi Moderator @Dimitrios Kanellopoulos
                      @Dimitrios-Kanellopoulos said in S9 barometer problems:
                      I wrote something similar just days ago 🙂
                      And yes, my Edge registers hundreds of meters of ascent in Amsterdam, that gladly Runalyze fixes on its own.
