    "Power saver tilt "... not working after a while
    6 Posts 5 Posters 438 Views 5 Watching
    • K Offline
      kasperle
      Hi folks,
      I’m new within the Suunto Community and happy with my brandnew Suunto 7 😁
      But…
      there is one a bit annoying thing:
      I set the energy option like mentioned in the manual:
      • Keep Power saver tilt on
      • Keep Tilt-to-wake off
      • Keep Always-on screen turned off
      Mostly everything is fine but after a while turning my wrist won’t show the low-power version of the used “Heatmaps watch face”. The display stays dark. The only way to activate something is touching the Display several times…
      Is that a normal behavior or is that something to investigate ??
      Thanks in advance!!
      Reimar
      Brad_OlwinB olymayO K 3 Replies Last reply Reply Quote 0
        Brad_Olwin Moderator @kasperle
        @kasperle Try a soft reboot and see if that helps. Long press upper left button for 12s until the watch restarts.
        • olymayO Offline
          olymay Gold Members @kasperle
          @kasperle My experience with the power saver tilt simply brightens the low power display a little when you tilt the watch up to look at it (useful when outside but less so inside I find). It will not show any extra information such as the heatmap etc.
          I currently have the power saver tilt disabled as it can interfere with following a route when tracking an activity.
          Suunto 7 Graphite Copper
          • K Offline
            Kramble @kasperle
            @kasperle I have the exact same issue with the suunto watchface and the others.
            Ambit 3 peak saphir
            Spartan Ultra (sold)
            S7 graphite copper
            S9 peak all black
            Wings
            • K Offline
              kasperle @Brad_Olwin
              @Brad_Olwin I’ll try that… maybe there’s a connection between the reported behavior and notifications… I continue to observe this issue and report again 😉
                this is a known bug I think.
                What happens is this.
                You change the settings to what you want A. -> All work ok.
                then you open Suunto app on the watch and the Suunto app remembers that setting
                You change the setting to something else B
                You open suunto app and once you close it it restores setting A instead of B
                To over come this you need to reboot the watch as it wipes out the setting that Suunto app remembers and sets back every time you open / close it
