    Suunto 9 baro very low elevation gain vs other brands
    148 Posts 21 Posters 24.1k Views 20 Watching
    • OktanO Offline
      Oktan
      OK. then last sentence from my side:
      I’m a programmer too.
      If I had in my program a constant (that its value can be argued) which fits 90% of the users, but the other 10% nagging the same issue over and over and consuming 20% of my time for explanation & proof - I would consider to let them change it (just a bit) for their own fine tuning ( and hapiness 🙂 ).
      Suunto 9 Baro Titanium & Ambit 3 Peak
        Dimitrios Kanellopoulos Community Manager @Oktan
        @Oktan the best would be (although not easy) to allow you to change that. Suunto cannot change it for all because then the other percentage will complain then for example.
        I think that is the best solution for all. User power.
        • OktanO Offline
          Oktan
          I meant that 3 will be the default threshhold in the setting so the 90% will obviously wont change it, hence will not complain.
          Anyways, thank you for your time, patience and all that you do for us.
            @Oktan yeah I got it pal.
            • fazelF Offline
              fazel Bronze Member @Dimitrios Kanellopoulos
              @Dimitrios-Kanellopoulos Sorry - I thought my data was unconcerning and should have been clear. For me - this was within an acceptable range of deviation. I was relieved to be honest. You didn’t have to do all of this. I apologize for frustrating you.
                Dimitrios Kanellopoulos Community Manager @fazel
                @fazel no no. It’s ok. I just wanted to explain that many times we can miss some fault etc.
                To be honest if I could I would make you a tester as you did take the time Todo that great run and compare.
                Actually at your data the s9 I think did a boo boo at the end as I said which I reported.
                fazelF 1 Reply Last reply Reply Quote 2
                • fazelF Offline
                  @Dimitrios-Kanellopoulos thank you - are you referring to the GPS track at the end?
                  I would love to be a tester. If that ever becomes a possibility please let me know.
                    @fazel no at the elevation difference if you take a look.
                    fazelF 1 Reply Last reply Reply Quote 1
                    • fazelF Offline
                      @Dimitrios-Kanellopoulos oh wow. I see it now.
                        freeheeler
                        I went backcountry skiing with my friend who has well deserved and honourable inherited my A3PS. Of course the watches were not on the same arm, hence a comparison with the slightest scientific touch isn’t possible. However I would like to mention here that we went in the exactly same ascent track and his A3PS recorded around 100m less total ascent plus had issues with the track on the first few meters.
                        My takeaway is that S9B is not inaccurate at all.
                        Plus: it’s crazy good to enjoy sports without having issues like these in mind 🙂 life is easier when we don’t worry
                        OktanO 1 Reply Last reply Reply Quote 8
                        • OktanO Offline
                          Oktan @freeheeler
                          @TELE-HO Can it be that his jacket blocked the barometer hole for a small period of time, and yours didnt?
                            freeheeler @Oktan
                            @Oktan
                            no, not on A3PS and also not possible when I check the graph
                            • stromdiddilyS Offline
                              stromdiddily Gold Members
                              Interesting one for me today…S9 more than doubled the ascent/descent on my route. Green graph is a lot more jagged than the typical results.
                              Pouring down rain today but it was constant the whole time.
                              fazelF freeheelerF 2 Replies Last reply Reply Quote 0
                              • fazelF Offline
                                fazel Bronze Member @stromdiddily
                                @stromdiddily so light green is today, dark green is a track from the same route ran in the past? I see this sort of delay with FusedAlti, @Brad_Olwin has as well.
                                  stromdiddily Gold Members @fazel
                                  @fazel green is today, yellow-ish is from three months ago on the same 7 mile route. The start looks ok tbh but the green is reporting over 1k feet of climbing and the yellow is correctly showing 500ish feet.
                                  Edit - QS feature request, ability to assign colors to merged tracks 😄
                                    freeheeler @stromdiddily
                                    @stromdiddily
                                    the spike-ish graph looks like hydraulics did magic on the sensor… it’s a wild guess, but possible
                                    fazelF 1 Reply Last reply Reply Quote 0
                                    • fazelF Offline
                                      fazel Bronze Member @freeheeler
                                      @TELE-HO hydraulics = water?
                                        freeheeler @fazel
                                        @fazel
                                        my assumption… pouring rain and the baro holes right next to the wrist… it seals great and the movement could create pressure that causes a down spike. once relieved it shows an up spike.
                                        for our luck the recording is not set to every second as it was possible with Ambits, hence it’s somehow equalling out a bit… or let’s say it would be worse
                                        • Fenr1rF Offline
                                          Fenr1r @freeheeler
                                          @TELE-HO Sleeve pump effect?
                                          stromdiddilyS 1 Reply Last reply Reply Quote 1
                                            stromdiddily Gold Members @Fenr1r
                                            @Fenr1r That’s how I normally wear it, but you’re probably right 🤷
